al-yeti Posted February 11, 2018 Share Posted February 11, 2018 25 minutes ago, LeepyLee said: Thank you all! I particularly like the 150 yrs old comment! Not a lot of help, but my kind of humour! Thanks for the link to Manager Manual too, but does anyone know where I can find a programming manual please, in case I take up the challenge to reset/default or start from scratch? Looks like you been in there already, just like my installs excellent Quote Link to comment Share on other sites More sharing options...
norman Posted February 11, 2018 Share Posted February 11, 2018 Nah, typical national job that's been taken over a dozen times over the years to save tuppence. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
MrHappy Posted February 11, 2018 Share Posted February 11, 2018 35 minutes ago, LeepyLee said: Not a lot of help, but my kind of humour! Not very helpful, why have you got a property or home with no codes to the alarm ? Personally I think you'd be better calling a co. however we'd only be interested in replacing the controls, but we should be able to retaining the other devices Quote Mr Veritas God Link to comment Share on other sites More sharing options...
MrHappy Posted February 11, 2018 Share Posted February 11, 2018 25 minutes ago, norman said: Nah, typical national job that's been taken over a dozen times over the years to save tuppence. SD1+GJD make me think its a hous & the 1313 + surge purge say either problem site or the last controls went "puff" in a storm? 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
norman Posted February 11, 2018 Share Posted February 11, 2018 Yeah maybe, but I have seen both on commercial. Missed the 1313 good spot. Either way they are too tight to pay for proper monitoring. Eta, the bad stipple artex would also point to a resi,but the painted wall for the keypad? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Nova-Security Posted February 11, 2018 Share Posted February 11, 2018 6 minutes ago, norman said: Yeah maybe, but I have seen both on commercial. Missed the 1313 good spot. Either way they are too tight to pay for proper monitoring. Eta, the bad stipple artex would also point to a resi,but the painted wall for the keypad? Also only 4 circuits in use unless there is an expander CD95 still on of my fav panels, only issue was programming outputs they wouldn't change until you come out of engineers Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
LeepyLee Posted February 12, 2018 Author Share Posted February 12, 2018 This system is in a rental property that's been empty for a while. Last tenant never knew the codes so never used the alarm. The internal sounder only, was going off when landlord & I visited. He managed to silence the sounder by using the 'poke & hope' method. But after that, no response from panel... obviously because of data fault. As there are only four wires (presumably power & data pairs) between panel & keypad, its easy enough to prove the cabling. Assuming the cabling is OK, is there a way to prove if the keypad or panel is at fault other than by swapping one or the other? The keypad is obviously getting power as the display is lit. Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted February 12, 2018 Share Posted February 12, 2018 1 hour ago, LeepyLee said: Assuming the cabling is OK, is there a way to prove if the keypad or panel is at fault other than by swapping one or the other? The keypad is obviously getting power as the display is lit. Take the keypad off and wire on on short lead next to the panel or meter the cables out Its getting parts to swap over that you will find very hard unless there are some on ebay Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
LeepyLee Posted February 12, 2018 Author Share Posted February 12, 2018 Yeah, as I say assuming the cabling is OK, once proved, is there a way to prove if the keypad or panel is at fault other than by swapping one or the other? I.e. by using a meter, is it possible to test the data pair both ways, looking into the panel and into the system; what conditions should I see or measure? Quote Link to comment Share on other sites More sharing options...
