IanP Posted February 1, 2018 Share Posted February 1, 2018 Hello, first post! I've got a Securit 700L system with zones 1, 2, 3 & 4 used with PIRs. Zone 1 is by default Entry / Exit. I'd like to make Zone 3 the same, so I can enter/leave via a door in that zone also. I've got the manuals but cannot see a way of doing it... Any clues would be welcome!!!! Thanks. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 1, 2018 Share Posted February 1, 2018 Do you have engineer code? Do you have installation manual? Does the walk route from zone 3 go via any other zones apart from zone 1 ? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 1, 2018 Share Posted February 1, 2018 49 minutes ago, IanP said: I'd like to make Zone 3 the same, so I can enter/leave via a door in that zone also. your 20 odd yr old controls doesn't do that you've the choice of changing the wiring or change the controls, Quote Mr Veritas God Link to comment Share on other sites More sharing options...
IanP Posted February 1, 2018 Author Share Posted February 1, 2018 49 minutes ago, al-yeti said: Do you have engineer code? Yes Do you have installation manual? Yes Does the walk route from zone 3 go via any other zones apart from zone 1 ? No 18 minutes ago, MrHappy said: your 20 odd yr old controls doesn't do that you've the choice of changing the wiring or change the controls, Thanks, not what I wanted to hear!!! Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 1, 2018 Share Posted February 1, 2018 22 minutes ago, MrHappy said: your 20 odd yr old controls doesn't do that you've the choice of changing the wiring or change the controls, Serious you can't make two zones entry? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 1, 2018 Share Posted February 1, 2018 33 minutes ago, al-yeti said: Serious you can't make two zones entry? nope, it old old tat Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted February 1, 2018 Share Posted February 1, 2018 16 minutes ago, MrHappy said: nope, it old old tat Diy stick both detectors on one zone and lash it in Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 1, 2018 Share Posted February 1, 2018 6 minutes ago, al-yeti said: Diy stick both detectors on one zone and lash it in only way on this panel Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
MrHappy Posted February 1, 2018 Share Posted February 1, 2018 22 minutes ago, james.wilson said: only way on this panel final exit circuit on door(s) & PIR on entry route, thats how it was done when I was young, keen & slim(er) Quote Mr Veritas God Link to comment Share on other sites More sharing options...
james.wilson Posted February 1, 2018 Share Posted February 1, 2018 keener too probs lol Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted February 1, 2018 Share Posted February 1, 2018 2 hours ago, IanP said: Thanks, not what I wanted to hear!!! Changing the wiring is not that hard, remove wires from zone three fit link, remove one wire from zone one join it to one of the wires removed from zone 3, put the other wire from zone three in the vacant hole of zone one. This will do what you want but, if you have a false alarm on zone one you will never know what detector caused it Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 1, 2018 Share Posted February 1, 2018 29 minutes ago, PeterJames said: Changing the wiring is not that hard, remove wires from zone three fit link, remove one wire from zone one join it to one of the wires removed from zone 3, put the other wire from zone three in the vacant hole of zone one. This will do what you want but, if you have a false alarm on zone one you will never know what detector caused it As Al its a bodge will work like driving down the road with no windscreen, doors, seatbelts etc, will still work but not advised Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
IanP Posted February 1, 2018 Author Share Posted February 1, 2018 48 minutes ago, PeterJames said: Changing the wiring is not that hard, remove wires from zone three fit link, remove one wire from zone one join it to one of the wires removed from zone 3, put the other wire from zone three in the vacant hole of zone one. This will do what you want but, if you have a false alarm on zone one you will never know what detector caused it Thanks, I'll give my local pro a bell... Quote Link to comment Share on other sites More sharing options...
IanP Posted February 2, 2018 Author Share Posted February 2, 2018 13 hours ago, james.wilson said: As Al its a bodge will work like driving down the road with no windscreen, doors, seatbelts etc, will still work but not advised Just thinking... would a second keypad in the garage, which would not be itself alarmed, be a better solution than combining zones? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted February 2, 2018 Share Posted February 2, 2018 A keypad outside the protected area is always a good idea, if you make sure that its well warn on the numbers that make up your code. Really it all depends on the risk, I am guessing you havent got anything worth protecting, otherwise you wouldnt be here you would be having a proper alarm installed. Which means the type of burglar that will target you would most likely be an opportunist and not someone that has spent time watching you come and go and planned the heist of the century. So yes putting a keypad outside the protected area will work for you, but keep it clean, and bear in mind its not recommended. Quote Link to comment Share on other sites More sharing options...
IanP Posted February 2, 2018 Author Share Posted February 2, 2018 3 minutes ago, PeterJames said: A keypad outside the protected area is always a good idea, if you make sure that its well warn on the numbers that make up your code. Really it all depends on the risk, I am guessing you havent got anything worth protecting, otherwise you wouldnt be here you would be having a proper alarm installed. Which means the type of burglar that will target you would most likely be an opportunist and not someone that has spent time watching you come and go and planned the heist of the century. So yes putting a keypad outside the protected area will work for you, but keep it clean, and bear in mind its not recommended. ? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted February 2, 2018 Share Posted February 2, 2018 The first line was sarcasm sorry Just now, PeterJames said: The first line was sarcasm sorry Its my sense of humour a bit dry for some people no offence intended Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 2, 2018 Share Posted February 2, 2018 No detection in garage, means you can get to it without starting try tomorrow or full alarm Quote Link to comment Share on other sites More sharing options...
IanP Posted February 2, 2018 Author Share Posted February 2, 2018 1 minute ago, al-yeti said: No detection in garage, means you can get to it without starting try tomorrow or full alarm The garage, which its in full view of the other ten houses in a quiet and (so far) crime-free cul-de-sac has a police-approved sectional door with no external lock or handle, just a BiSecur radio system operated from the car. So maybe not what you envisioned Quote Link to comment Share on other sites More sharing options...
PeterJames Posted February 2, 2018 Share Posted February 2, 2018 the glass looks really clean Quote Link to comment Share on other sites More sharing options...
IanP Posted February 2, 2018 Author Share Posted February 2, 2018 1 minute ago, PeterJames said: the glass looks really clean Virtually transparent. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted February 2, 2018 Share Posted February 2, 2018 So what happens when it rains does the car get wet? Quote Link to comment Share on other sites More sharing options...
