SFB Solutions Posted January 24, 2018 Share Posted January 24, 2018 Hi All, I was wondering if anyone had any ideas on an issue ive had today. I have upgraded an existing CCTV System from an old PC based system to a DVR but the DVR is restarting around every 10 mins. I have disconnected all monitors bar my test monitor and it still did it changed the HD removed the HD changed the power supply changed the password Camera wiring remains original and I'm thinking I could maybe have some power coming up one of the existing cables which over loads the dvr in some way and restarts it. Any ideas before I give in and call support Thanks Quote Link to comment Share on other sites More sharing options...
PeterJames Posted January 24, 2018 Share Posted January 24, 2018 psu probably, are you sure that you have used the one that came with the recorder? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 24, 2018 Share Posted January 24, 2018 12 minutes ago, PeterJames said: psu probably, are you sure that you have used the one that came with the recorder? Init Quote Link to comment Share on other sites More sharing options...
SFB Solutions Posted January 25, 2018 Author Share Posted January 25, 2018 100% the one that came with the recorder unfortunately, ill take it back today. Thanks Quote Link to comment Share on other sites More sharing options...
PeterJames Posted January 25, 2018 Share Posted January 25, 2018 did you fit the HDD sometimes they pull the power down as do fans ect Quote Link to comment Share on other sites More sharing options...
SFB Solutions Posted January 26, 2018 Author Share Posted January 26, 2018 yes I always buy barebones kit and install my own drives. It has had three different HD installed It is going back to supplier today for a replacement. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted January 26, 2018 Share Posted January 26, 2018 my money would be on the PSU Quote Link to comment Share on other sites More sharing options...
SFB Solutions Posted February 1, 2018 Author Share Posted February 1, 2018 I would have said exactly the same but I tried a new one out of a spare I had and it still restarted. Returned it to the supplier and replaced it with a Viper which has been faultless since Thank you for your ideas and help guys Quote Link to comment Share on other sites More sharing options...
satsuma01 Posted February 24, 2018 Share Posted February 24, 2018 What app on mobiles does the qvis range use and how stable I'd the app to the DVRs Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment Share on other sites More sharing options...
SFB Solutions Posted March 13, 2018 Author Share Posted March 13, 2018 Sorry i have only just seen this. It depends which DVR you are using, i have systems on the Explorer App and Super Live Plus, i find both reliable. Quote Link to comment Share on other sites More sharing options...
