Galaxy GX push notifications
Put a Ethernet mod in so I can connect remotely and also have the system go direct to me rather than through the arc
however I can connect remotely when I'm on my home network but can't connect when I'm away from my network.
I only install secures and GSMs so not really got into using Ethernet mods at all and galaxy tech are a nightmare
any ideas for help
You need to connect to your home network by VPN or port forward. Port forward is easier to set up, but not advisable as a secure solution.
If your broadband account does not offer a static IP address, you will need to use a dynamic DNS provider to resolve your WAN IP address in order to connect back to your home router.
Done all that. Followed every step of instruction I can find online.
Nothinh works.
Now Only thing I can think of is I have no connection password so I leave this blank. I can connect without it on my phone when I'm on me home network but not when I switch off wifi. Could this be cause
Yuck. Cloud / hole punching is deffo the way to be if you want self monitoring.
Did you call the port fowards on the BT hub things like 'Alarm'?
I have had trouble using names like 'CCTV' on a HH4. Tearing my hair for hours until I changed the name. Then it all worked.
I assume due to the fact there was an entry already named 'CCTV' etc... on the useless drop-down list of pre-filled port forwards, and obviously not picked up in testing.
