gazh Posted November 19, 2017 Share Posted November 19, 2017 hi lads can anyone help . ive got a veritas 8 system in my house which was installed before we bought the property , the alarm has been working ok up till now where when we set the alarm itjust keep beeping and wont set , when doing a walk test its saying zone 3 which is just a pir , even when alarm is not set the pir is just constantly flashing on and off , is it time to change the pir as im assuming there is nothing wrong with the wiring as its been working ok . any help appreciated thanks gaz Quote Link to comment Share on other sites More sharing options...
aissecur Posted November 20, 2017 Share Posted November 20, 2017 Hi, are you saying the pir led is flashing even with no movement in the protected area? Have you any other pirs on the alarm system? (can you compare the behaviour of this one to the rest?) Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 20, 2017 Share Posted November 20, 2017 Could possibly be a faulty sensor. Have you tested anything or used your multimeter yet? Quote Link to comment Share on other sites More sharing options...
george.h Posted November 20, 2017 Share Posted November 20, 2017 Potentially even a literal "bug" in the sensor.... depending on how well sealed it is.... Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted November 20, 2017 Share Posted November 20, 2017 Does the 'pir' also have green and yellow lights? Very unlikely for a v8 grade installation but just wondering if its a risko detdctor indicating 'mask'. Also don't some Honeywells do this when they fail self test? Assuming you do mean the pir itself is flashing. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
magpye Posted November 21, 2017 Share Posted November 21, 2017 18 hours ago, george.h said: Potentially even a literal "bug" in the sensor.... depending on how well sealed it is.... Sensors have been sealed against your 'bugs' for years now, I would be very surprised if that's it . Not a problem these days. 1 Quote Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 21, 2017 Share Posted November 21, 2017 The better quality ones anyway. Wouldn't fit sensors without sealed optics, unless I had no option like wireless for example. Quote Link to comment Share on other sites More sharing options...
