BeechStu Posted October 18, 2017 Share Posted October 18, 2017 Hi I have Menvier Ts2500 that keeps alarming after battery removed. Any ideas why? Quote Link to comment Share on other sites More sharing options...
norman Posted October 18, 2017 Share Posted October 18, 2017 Replace the battery? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
BeechStu Posted October 18, 2017 Author Share Posted October 18, 2017 Hi . It is only when I remove the battery that this fault occurs? Keypad will scroll through random messages as well! Quote Link to comment Share on other sites More sharing options...
MrHappy Posted October 18, 2017 Share Posted October 18, 2017 why are you removing the battery ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
BeechStu Posted October 18, 2017 Author Share Posted October 18, 2017 Hi . Just for testing . Quote Link to comment Share on other sites More sharing options...
sjsturner Posted October 18, 2017 Share Posted October 18, 2017 Have you powered the whole system down and back up? i have done this before to clear network errors.sounds like you may have some interference or a ****** panel, have you tested for induced AC and checked the cable insulation? please note though, not all TS 2500 come back to life from a full power down lucky for me, mine are immortal Quote Link to comment Share on other sites More sharing options...
BeechStu Posted October 18, 2017 Author Share Posted October 18, 2017 Thanks for your help! I think it is the panel! Quote Link to comment Share on other sites More sharing options...
petercts Posted October 18, 2017 Share Posted October 18, 2017 The psu was a major problem on these does not like to keep 17 ah battery fully charged. it uses the battery like a giant smoother capacitor if the panel powered any thing other than the sas or redcare it pushed it to its limit so had to always power network and detectors from separate psu Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 18, 2017 Share Posted October 18, 2017 Sounds like the PSU/transformer is failing or has been overloaded. Had this with 2500 and 900's Quote Link to comment Share on other sites More sharing options...
MrHappy Posted October 18, 2017 Share Posted October 18, 2017 9 hours ago, BeechStu said: Hi . Just for testing . how are you testing the battery ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
PeterJames Posted October 18, 2017 Share Posted October 18, 2017 11 hours ago, BeechStu said: Hi I have Menvier Ts2500 that keeps alarming after battery removed. Any ideas why? Its probably telling you that it has a battery missing Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 18, 2017 Share Posted October 18, 2017 You'd normally get the fault tone with the battery removed not full alarm. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted October 19, 2017 Share Posted October 19, 2017 17 hours ago, sixwheeledbeast said: You'd normally get the fault tone with the battery removed not full alarm. I thought maybe thats what he meant, customers often confuse tamper tones with alrm going off Not only that it will go off again shortly after resetting it Quote Link to comment Share on other sites More sharing options...
