brokenrecord Posted August 25, 2017 Share Posted August 25, 2017 Hi folks - anyone got any wisdom to share? We have a Veritas R8 installed in our rented bungalow (I think - that's what it says on the control panel). We never use it as we have a cat... Lately it's been going off a lot. The box for it is up in the loft. We hear it making a noise and then you go to the control panel. It isn't doing anything. If you push buttons the control panel starts beeping. Put in the code and it stops. Happening about twice a day. Also the light outside is flashing intermittently for hours and sometimes it won't turn off at all. I really just want to disable the whole thing - can anyone tell me how? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 25, 2017 Share Posted August 25, 2017 18 minutes ago, brokenrecord said: Hi folks - anyone got any wisdom to share? We have a Veritas R8 installed in our rented bungalow (I think - that's what it says on the control panel). We never use it as we have a cat... Lately it's been going off a lot. The box for it is up in the loft. We hear it making a noise and then you go to the control panel. It isn't doing anything. If you push buttons the control panel starts beeping. Put in the code and it stops. Happening about twice a day. Also the light outside is flashing intermittently for hours and sometimes it won't turn off at all. I really just want to disable the whole thing - can anyone tell me how? What's landlord say? Is he willing to fix it and get an engineer in and pay for it? Or did he say you guys do as you need to Quote Link to comment Share on other sites More sharing options...
aissecur Posted August 26, 2017 Share Posted August 26, 2017 To me it sounds like you have an intermittent tamper issue.... All the devices within a normal alarm system (detectors / bellbox / control panel / keypad etc) are normally tamper protected (I use the term normally as not every body installs to the same standards) Its is likely that there is an issue with one of these devices or the cable that goes to it. I would be certainly asking the landlord (or reviewing your tenancy agreement) to understand where the responsibility lies before doing anything . Quote Link to comment Share on other sites More sharing options...
brokenrecord Posted August 26, 2017 Author Share Posted August 26, 2017 Ha, thanks both. My agent told me to google it. Would you say it needs an engineer then, and it's not something I could sort myself? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted August 26, 2017 Share Posted August 26, 2017 I would tell the landlord to sort it and can't (can) believe they would invite a tenant to interfere with mains electricity / high voltage bellboxes at height etc... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 26, 2017 Share Posted August 26, 2017 Sounds like the landlord needs to get someone out to either service it or decommission it. If your a tenant it's not your call on having it removed etc. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 26, 2017 Share Posted August 26, 2017 3 hours ago, brokenrecord said: Ha, thanks both. My agent told me to google it. Would you say it needs an engineer then, and it's not something I could sort myself? If cost is reasonable and repairable then how long you staying there is worth a little security Quote Link to comment Share on other sites More sharing options...
norman Posted August 26, 2017 Share Posted August 26, 2017 As above it's more than likely (unless expressly excluded in your agreement) your Landlord's responsibility, why bother wasting your time? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
brokenrecord Posted September 7, 2017 Author Share Posted September 7, 2017 It was easier to spend time seeing if i could fix the alarm myself than spend the time convincing my letting agent to fulfill their part of the bargain! But i've shown them your responses and now we will get an engineer - thanks everyone! Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 7, 2017 Share Posted September 7, 2017 It's the right choice. You would be liable if you made the decision to DIY or get someone out. Quote Link to comment Share on other sites More sharing options...
aissecur Posted September 7, 2017 Share Posted September 7, 2017 My family has a property they rent out and it has an alarm in it, if there were any issues with it I certainly would not expect the current tenant to put their hand in their pocket to resolve unless it was due to malicious damage. Quote Link to comment Share on other sites More sharing options...
norman Posted September 7, 2017 Share Posted September 7, 2017 On 26/08/2017 at 13:20, norman said: As above it's more than likely (unless expressly excluded in your agreement) your Landlord's responsibility, why bother wasting your time? 25 minutes ago, aissecur said: My family has a property they rent out and it has an alarm in it, if there were any issues with it I certainly would not expect the current tenant to put their hand in their pocket to resolve unless it was due to malicious damage. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
al-yeti Posted September 7, 2017 Share Posted September 7, 2017 7 hours ago, aissecur said: My family has a property they rent out and it has an alarm in it, if there were any issues with it I certainly would not expect the current tenant to put their hand in their pocket to resolve unless it was due to malicious damage. Doesn't even make sense , if landlord isn't bothered and tenant doesn't mind paying , don't be Muppets Adt make good money on rentals , landlord gets a box on the house , all at tenants cost Quote Link to comment Share on other sites More sharing options...
norman Posted September 7, 2017 Share Posted September 7, 2017 If it's existing it should be covered unless explicitly excluded. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
