Part set Enforcer?
No idea what the problem is. I've checked inputs are assigned to the Zones in question, I've enabled flexi set, I've done everything that I can possibly think of, plus the advice given on this thread. I've initiated a clean start, still no fix.
I can only assume that there's some kind of fault with the system until Pyronix get back to me.
Thanks for all the advice so far. Will update when I hear back from Pyronix.  Any other suggestions more than welcome in the meantime ;-)
2 minutes ago, Amps said:
Only other thing i can think of and not sure if it will make any difference. Do you have a final exit zone for area B?
Thought b was part set , or is this like the scanny abcd
Yes, it has a final exit. I even tried changing this to entry/exit route just to see if it made a difference, but still didn't.
Yes B is part set, although it has no inputs assigned to it at first so it has to be done manually.
Have you enabled flex set for that user?
You have to enable flex set globally and then for each user.
im not sure if it's needed as I always have one set, but you may need a zone setting as FX or ER
You also need zones assigned to area A & B to uses areas A & B !
  • Like 1
This was the problem!
I thought 'Flexi Set' was a global option only, and whatever you set it as using the Engineer Code would be a global thing, but apparently not.
Thanks for this, and thanks to everyone else on the thread for taking the time to help me with this issue, your experience and expertise has been greatly appreciated.
On 17/08/2017 at 12:27, fatman said:
I have flexi set enabled for the user.
You mean in System Options flexi set was turned off?
Im sure the default is flexi set on. Did you turn it off?
Glad you got it sorted.
  • Like 1
I think the main problem is that I was inputting the master manager code instead of the user code (which wasn't set), but once I added a user, set user parameters for zones A and B, it worked.
But don't tell anyone that I was that stupid ;-)
