Lights switching on via occupancy detectors every time the external door is opened and the door alarm sensor activates. The alarm and lights are on different circuits, and cables do not run in close proximity to each other. Has anyone had this before?
  • Replies 28
Surely the occupancy sensor is just doing it's job? Assuming there ultrasonic or microwave and not IR.
If the only thing "connecting them" is the audible sound of the chime on the door have you disabled the chime to test?
The occupancy sensors may need adjusting.
Also who's John, the resident ghost?
1 hour ago, ffrowley said:
The door alarm is a contact with a buzzer that sounds on the alarm panel. The ceilings are plastered and the sensors are not on the same floor as the external door
What's your relationship in this ?
Your alarm, your electrics or your building ?
44 minutes ago, ffrowley said:
-I'm sure the sensors are IR I'll have to have a look when I go back.
-I haven't disabled the chime yet... :)
-I've installed the lights with occupancy detectors
So have you damaged a cable somewhere or left something loose , all possible
Its very unlikely the alarm is doing something to trigger the occupancy sensor.
Mask your sensor(s) over with electrical tape, open door external *IF* there's a weird interconnection between the systems your lights will come on.
I assume opening the door is causing something to move within the area of the occupancy sensors eg- blinds, house plants or some weird reflection on the glass of the opening door reflecting onto the glass of another building into the room with the occupancy sensors
Reducing the sensitivity of your occupancy sensor(s), is where I would start.
