Joe Doherty Posted July 18, 2017 Share Posted July 18, 2017 CSL Miniair is not bad little device for upgrading older panels & bells only jobs to app style system. Remote Arm/Disarm is useful. Had a issue where i couldn't connect to the Installer App but CSL changed all the settings for me No Problem. Can connect through Digimodem via Dialcapture (Contact ID Only) Set up your zones to display in the App, You can also connect via General Alarm Input (Bell Trigg) Both methods need a SET output going to SET on Miniair this shows device Armed Disarmed Status on the App. The Keyswitch output only supports panels with a momentary keyswitch input, however most older panels require latching like with the Galaxy i got sent from Pillar to post but found the solution even CSL have adopted this now and ordered the relays to trial. Anyone wanting to set up a miniair on a panel using a NC zone as a keyswitch, You are going to need a Bentley Toggle Relay model AT 223 & Two 10K resistor's, 1. Wire one leg of your resistor from 12v to input 1 then put the other leg from 12v to Input 2 ensure they are not touching 2. Then fit Jumpers links on J1 & J2 3. Connect orange OUT wire from miniair to IP1 on relay 4 Power Relay from Aux This set up will work for dial capture or just using the general alarm When the relay receives a negative applied pulse from miniair it goes open it then stays in that state until pulse is replied closing input thus setting and unsettling the alarm via the app Hope you find this little review use full Thanks, Joe Quote Link to comment Share on other sites More sharing options...
james.wilson Posted July 18, 2017 Share Posted July 18, 2017 it is proper little ty joe Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
datadiffusion Posted July 19, 2017 Share Posted July 19, 2017 So... do you buy direct from CSL, no monitoring co. involved? Then monthly app fee to CSL direct? Just realised this section isn't strictly trade only; price would be of interest I'm sure, even to those not intending on using it. I'm guessing it comes with a £1.99 antenna rather than the usual big CSL jobbie? Thanks for the review though - esp. the relay. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
norman Posted July 19, 2017 Share Posted July 19, 2017 10 hours ago, james.wilson said: it is proper little Either that or he has fecking mahoosive hands. Looks tiny for 1kg.... Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
GalaxyGuy Posted July 19, 2017 Share Posted July 19, 2017 Trying to remember who the OEM is for these modules. I think these guys re-brand it too. http://www.mini01-4g.com/ Quote Link to comment Share on other sites More sharing options...
james.wilson Posted July 19, 2017 Share Posted July 19, 2017 its an eastern European manufacturer but i forget too can it only do contact id, ie no sia 3? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted July 19, 2017 Share Posted July 19, 2017 m2mservices Sofia? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted July 19, 2017 Share Posted July 19, 2017 Ah, yes. That was it. Quote Link to comment Share on other sites More sharing options...
Joe Doherty Posted July 19, 2017 Author Share Posted July 19, 2017 (edited) You order them through your ARC Same price as a Digiair, You may be able to order via CSL for App connection Only not sure, Yeah only Supports Contact ID at the moment as far as i am aware, Or can just wire it via bell trigg input. This shows up as General Alarm Yes comes with standard stick on antenna Edited July 19, 2017 by Joe Doherty Quote Link to comment Share on other sites More sharing options...
james.wilson Posted July 19, 2017 Share Posted July 19, 2017 12 hours ago, sixwheeledbeast said: m2mservices Sofia? Can you buy it from them or is it a licence deal in the uk? 11 minutes ago, Joe Doherty said: You order them through your ARC Same price as a Digiair, You may be able to order via CSL for App connection Only not sure, Yeah only Supports Contact ID at the moment as far as i am aware, Or can just wire it via bell trigg input. This shows up as General Alarm Yes comes with standard stick on antenna What does it cost? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
