Hikvision Password reset... AGAIN!
Hi,
Yet again I have powered up a DVR and the thing is locked out, lost count how many times this has happened!
Is there anyway to factory reset this? or is it the usual email Hikvision to unlock?
Ive tried the online help which seems to work if you have the double click bottom left function on the login screen, mine just has forgot password.
cheers
7 minutes ago, connor2425 said:
Hi,
cheers
You should be fine if you contact hik? I don't get it , this is standard stuff they help you with , or you doing everything via a fith party?
I have been praising hik as a budget option
Aaron asked why I was so sure
On looking the dearer stuff seems good, but the turbo stuff seems shite. SIA has had issues on just over 30% of it.
I'm assuming that's what Aaron meant
48 minutes ago, connor2425 said:
I do like Hik, but this will probably be the last. Online the solution seems to be through the SADP software but again I cant enter the code supplied as mine is different.
Is it right there firmware is updated as much as texe
it must be your supplier, i've never had a hik dvr  from dynamic, adi or ezcctv that didn't come inactive ready for a fresh password, but i did have a couple from cctv direct that had clearly been returns, the cameras had even been named till, shop left etc.
if you tftp new firmware on them the password will reset to inactive, just be sure to use the right firmware as it doesn't do any sanity checking that way, it will let you apply a wrong firmare but it wont like it.
