Itsadubthing Posted June 3, 2017 Share Posted June 3, 2017 Hi All, Just looking for a bit of advice. We have been using the Hik-Vision stuff for a while, but due to the current issues with the new Hik we decided to try out the Dahua HDCVI stuff. I installed a DHI-XVR5104HS with some DH-HAC-HDW2401EMP cameras. The problem I am having is when I plug them into the HDCVI BNC the camera is not stable and only comes on crackling and black& white. im sure this is just a setting but I cant seem to find anything about it anywhere. Please can you help Thanks C Quote Link to comment Share on other sites More sharing options...
Lwillis Posted June 3, 2017 Share Posted June 3, 2017 How are they wired? Cat5 with balauns or shotgun? 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 3, 2017 Share Posted June 3, 2017 1 hour ago, Itsadubthing said: Hi All, Just looking for a bit of advice. We have been using the Hik-Vision stuff for a while, but due to the current issues with the new Hik we decided to try out the Dahua HDCVI stuff. I installed a DHI-XVR5104HS with some DH-HAC-HDW2401EMP cameras. The problem I am having is when I plug them into the HDCVI BNC the camera is not stable and only comes on crackling and black& white. im sure this is just a setting but I cant seem to find anything about it anywhere. Please can you help Thanks C Also dahua are very helpful , do you not have access to there tech? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted June 3, 2017 Share Posted June 3, 2017 my first check would be connection or psu. Did u have connection issues with hik too? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Itsadubthing Posted June 4, 2017 Author Share Posted June 4, 2017 (edited) no never, and when i swap the bnc to the analogue end the picture is fine (low quality but fine) my first though was my BNC's. Its a brand new 2Ah psu but again I have tried another one also. 11 hours ago, Lwillis said: How are they wired? Cat5 with balauns or shotgun? shot gun cable Edited June 4, 2017 by Itsadubthing Quote Link to comment Share on other sites More sharing options...
Itsadubthing Posted June 4, 2017 Author Share Posted June 4, 2017 10 hours ago, al-yeti said: Also dahua are very helpful , do you not have access to there tech? I was just looking for a quick reply over the weekend Quote Link to comment Share on other sites More sharing options...
Lwillis Posted June 4, 2017 Share Posted June 4, 2017 Could be a few things as above check the psu,bnc ends is it copper cable or the chepo stuff? Quote Link to comment Share on other sites More sharing options...
ElecTech Posted June 4, 2017 Share Posted June 4, 2017 (edited) Seen something similar before. The camera has two outputs... HD-CVI and CVBS, looks like your in the opposite one to what the input is set as. Switch it and see what you get. *just saw the above post and you already have done. Check the input is set to HD-CVI and not analogue within the DVR settings. Can't remember where in the menu but can check one later if your struggling. Edited June 4, 2017 by ElecTech Quote Link to comment Share on other sites More sharing options...
Itsadubthing Posted June 4, 2017 Author Share Posted June 4, 2017 13 minutes ago, ElecTech said: Seen something similar before. The camera has two outputs... HD-CVI and CVBS, looks like your in the opposite one to what the input is set as. Switch it and see what you get. *just saw the above post and you already have done. Check the input is set to HD-CVI and not analogue within the DVR settings. Can't remember where in the menu but can check one later if your struggling. thanks for your suggestions ElecTech, im sure its just an input set wrong but searching through all the menus i cant seem to find anything. Quote Link to comment Share on other sites More sharing options...
ElecTech Posted June 4, 2017 Share Posted June 4, 2017 Try to set all inputs as CVI and see if anything changes. Quote Link to comment Share on other sites More sharing options...
Itsadubthing Posted June 4, 2017 Author Share Posted June 4, 2017 done that buddy still the same. in fact ive tried every input to be honest Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 4, 2017 Share Posted June 4, 2017 NTSC / pal issue? Quote Link to comment Share on other sites More sharing options...
ElecTech Posted June 4, 2017 Share Posted June 4, 2017 You probably have but once selected as CVI, give both the DVR and the camera a full power cycle. Quote Link to comment Share on other sites More sharing options...
Itsadubthing Posted June 4, 2017 Author Share Posted June 4, 2017 1 hour ago, ElecTech said: You probably have but once selected as CVI, give both the DVR and the camera a full power cycle. ill give that a go 4 hours ago, al-yeti said: NTSC / pal issue? how do i rectify that Quote Link to comment Share on other sites More sharing options...
Itsadubthing Posted June 7, 2017 Author Share Posted June 7, 2017 anyone else help please Quote Link to comment Share on other sites More sharing options...
james.wilson Posted June 7, 2017 Share Posted June 7, 2017 i think you have all that can be given without actually seeing it mate Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted June 7, 2017 Share Posted June 7, 2017 On 2017-6-4 at 9:48 AM, Itsadubthing said: I was just looking for a quick reply over the weekend Weekend gone, have you tried dahua yet? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 7, 2017 Share Posted June 7, 2017 What have you tried so far? Can you break down what and how you have tested? Quote Link to comment Share on other sites More sharing options...
JB_ Posted June 8, 2017 Share Posted June 8, 2017 (edited) Im a man of few words so........ CAMERA: DVR: Try it in CVBS mode? See if you pictures ok, whcih should prove connections and bnc's etc. Edited June 8, 2017 by JB_ Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 8, 2017 Share Posted June 8, 2017 Termination or Cable damage Do you have suitable test monitor ? If not take it down & put on fly lead nr dvr Quote Mr Veritas God Link to comment Share on other sites More sharing options...
mma Posted September 4, 2017 Share Posted September 4, 2017 This has probably been resolved by now but just incase here is what's happening. All the cvi cameras are all now 4MP. If you have bought a 2MP camera it's a 4MP camera that has been changed to 2MP in the camera settings. When you are in the PTZ settings if you double click it defaults the camera back to 4MP. If you only have a 2MP DVR you will get pictures like in the post. To resolve it you need either a 4MP test monitor or a 4MP DVR. To prevent it when you leave the PTZ menu click no if it's asking you to accept changes. Quote Link to comment Share on other sites More sharing options...
panelvan1 Posted February 24, 2018 Share Posted February 24, 2018 Did you sort this would like to know as have same problem, old post i know but worth a try. Quote Link to comment Share on other sites More sharing options...
