EUROSEC CPX CP8L KEY PAD
I will try my best to resolve it   if i carnt i will have the old system taken out.
If its a simple mess about with a setting on the panel it can be fixed if its hardware old **** tech issue causing a code L alarm then i take the stuff out.
Going round in circles here.
Any one who install or knows this panel have a look at the readings i have stated and advise how to change the settings. If you dont know i get it and the consensus on this forum risco and eurosec are not great. I sort that if i need to. You dont need to comment further.
Thanks all
