Can you spot the obvious problem in this photo
4 hours ago, MrHappy said:
Are both intruder & cctv done by the same mongs ?
22 minutes ago, PeterJames said:
Who said it was installed by an approved installer?
Unbelievably this is indeed a Nacos improved installer.
Many favourite part of the install is the chest high entry point for the cables. good for visual maintences.
  • Replies 58
The bell box and dcom antenna come out at a proper height, so why would the same installer not bring the CCTV cables out at the same level? It doesnt make sense, plus I dont know any professional co that runs two separate cables to a camera most would use external grade Cat 5 and Baluns or shotgun. I would say the cctv is by someone that saw a picture once and now thinks theyre a installer.
I'd guess a certian "beast of burden" has moved back to London
they use a very small bell label?
I guess there not very proud of the job...
Edited by MrHappy
  • Upvote 1
Mr? Veritas God
All the alarmfast and some of the chubb cctv jobs i've ripped out recently have been done in alarm cable and seperate rg59. Lots of them didn't have individually fused outputs on the psu either just a bit of choc block inside the 5a elmdenes with each individual camera able to draw the full 5a down tha alarm canle in a fault condition. From the ones i witnessed first hand it was down to inadequate supervision and monitoring of subbies by branch managers who couldn't give a **** as long as no one was hassling them into doing some actual work.
This was "installed " by service engineers. There was a Cctv fault and they couldn't find the psu so recabled it.
If I showed you what they done inside you would think it was a practical joke.
Whats worse is the Dvr is in the room the camera backs on to. They didn't even need to run the cable the way they did.
 NO ITS NOT THE WILD WILD WEST ITS THE MYSTIC EAST OF LONDON YOU GET WHAT YOU PAY FOR CCTV RUN IN CABLE TRAY (THE  RAIN GUTTER USALY STILL FIILED WITH WATER) OR MY ALL TIME FAV  CABLES SUPPORTED BY SKY HOOKS  OR DOES A SPEACH DIALER MEET GRADE 3 AND LEVEL 1 RESPONSE HAVE SOLD AND FITTED SYSTEMS IN THE AREA FOR THE LAST 40 YEARS HAVE NOT SEEN INSTALL STANDARDS  QUITE AS BAD AS THEY ARE NOW  THAT GOES FOR SOME NACOSS  SSIB  CO TOO
Edited by petercts
Do we allow the none Cornish to do caps lock?
  • Upvote 2
Mr? Veritas God
