Floureon CCTV home system power supply issues
3 minutes ago, Simon maddox said:
How what?
well I ain't a native American saying hello....
It says mode not supported on my tv screen
The resolution of the HDMI / VGA of the DVR is too high for the TV ?
Mr? Veritas God
So what do I need to do?It says mode not supported on my tv screen
What should I do?
What should I do?
Buy better TV ?
Question what TV model is ?
You could take the DVR to someone else where it might support the resolution then in the menu , change it to lower resolution and then bring it back to yours
But you must have an old TV if it doesn't display most models are atleast 1080p now and the DVR should have auto switched aswell
27 minutes ago, Simon maddox said:
What should I do?
Become Batman & fight injustice ?
or try a different telly / vga or composite video input ?
Log into its webpage & select a lower HDMI resolution ?
  • Thanks 1
Mr? Veritas God
It will have display settings in the menu, but you need to plug it in to  a tv with a higher resolution in order to get to the menu. I would do that before buying a new TV you may find you just have a dodgy HDMI lead or DVR
On 03/12/2019 at 08:58, datadiffusion said:
Sounds like Pete has a Floureon system at home ;)
Ive got piles of old tat that Ive ripped out and replaced, I use it to demo the rubbish over the good stuff  I counted 20 different brands from Anke to Swann in our test room, many have the same pcb different firmware
You are wonderful
I look up to you and think you are great
