360° Pyronix PIR?
Guest livewire
Guest livewire
Would you recommend using Pyronix 360° (or any other 360° PIR) ceiling mounted PIR
in kitchen / dinining room as per my attached sketch here.
I am very limited to positions where I could mount normal PIR ie. 2 corners are facing big Patio door (2.5m wide) , corner next to patio door has high vertical radiator below and the last corner has very high kitchen cabinets below it.
In addition there will be a door contact on the Patio door.
No problem using a 360 where you've stated provide it doesn't have to conform to DD243 (overlapping areas). We use the Optex FX35
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
29177[/snapback]
Lovely detectors the optex's, better than the Pyronix 360° any day.
The Pyronix 360° were a good detector, but have had several f/a problems with them recently.
I Don't know if it's a batch fault or a general manufacturing problem but I ended up taking them out and putting Rokonet RK-150T's (dual tech 360°) in instead.
Regards
Bellman
Guest livewire
Thanks for your views lads!
Apology I was not very clear which particular model is in question - this is Pyronix Octopus Super 360° Interlocking Quad Element Digital Ceiling Mount PIR Detector - are you talking about F/A-s for this particular model?
rgds
rgds
29226[/snapback]
Yes - I have had a few cause regular FAs on me.
OPTEX. OPTEX. OPTEX. Need I say more???
rgds
29226[/snapback]
Yup, that's the one,
I fitted a few of them to replace several older one's that had started f/a ing and sure enough, every other night since they were replaced they triggered, the previous octopus 360's had been in for years and had caused no problems at all, says a lot for the recent quality of the equipment...
I'll never fit another one, that's for sure.
Regards
Bellman
Whilst on the topic with regard to Optex has anyone been using the MX40QZ. Got a couple in to try but have not fitted them yet
