DCC Kid Posted September 24, 2019 Share Posted September 24, 2019 In my case it was 23.00 last night in the heavy rain up aladder trying to stop the AG6 sounder screeching. Not the first time - I have taken many steps with acrylic sealent on this box and it beggars belief how it gets in there - but it does! Thanks for the alternative makes suggested (Texecom, Elmdedne, SAB). IK Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 24, 2019 Share Posted September 24, 2019 1 hour ago, DCC Kid said: In my case it was 23.00 last night in the heavy rain up aladder trying to stop the AG6 sounder screeching. Not the first time - I have taken many steps with acrylic sealent on this box and it beggars belief how it gets in there - but it does! Thanks for the alternative makes suggested (Texecom, Elmdedne, SAB). IK Standard problem with the ag6 with no eave protection or just when weather hits it But then I have seen incorrect cabling , water trickles behind box , onto cable which trickles onto the PCB board on the ag6 , needs to be looped down out of the way really Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 24, 2019 Share Posted September 24, 2019 Texecom , deltabell, hkc box and others all better design and all have there quirks I don't like the old texe screw caps they all break or disintegrate Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 24, 2019 Share Posted September 24, 2019 Ody 1, 2 and 3 have small plastic bits that can fatigue and break after being in the sun. Would suggest Ody 4 or 5 if you go Texecom. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted September 25, 2019 Share Posted September 25, 2019 Did a job where the AG6 was pretty inaccessible but only about a year old so if it worked I intended to leave it (dumb builders positioning, not visible from frontage where I put a dummy) As it happened, it didn't work, but also as it happened the customer had scaff up for painting. It didn't work as wired incorrectly by builder (lol) but I did think what a crock it was when I wired it properly. Should have bloody changed it I think. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 25, 2019 Share Posted September 25, 2019 If it's in a position that is or has become inaccessible safely with ladders I always recommend a new bell in a repositioned location. It's then on the customer if it where to go wrong at 3am and you can't access it safely. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted September 25, 2019 Share Posted September 25, 2019 Unfortunately recently rennovated cottage with oak flooring over chipboard everywhere But at least a replacement in the same location would have been better than nowt. Had to rely on the wires the builders had provided and a well hidden expansion module back to back with what was a 4 core(!) to a PIR Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
DCC Kid Posted September 29, 2019 Share Posted September 29, 2019 On 24/09/2019 at 13:46, al-yeti said: Standard problem with the ag6 with no eave protection or just when weather hits it But then I have seen incorrect cabling , water trickles behind box , onto cable which trickles onto the PCB board on the ag6 , needs to be looped down out of the way really I agree - previously had to apply silicon sealant around rear of box and where cable enters (picture) as water did run along this. The last two times the water has capillaried from the bottom edge into the bottom of the electronics board. I have added more sealant today (picture). Just wanted to thank all respondents for the info on this. I have ordered a new Texecom Odyssey 4 to replace this with. 1 Quote Link to comment Share on other sites More sharing options...
