360 degree ceiling PIR Help please
Good afternoon Forum
I recently installed an Accenta Gen4 Alarm Panel - Metal Case alarm system from TLC-DIRECT and everything is working fine. I wanted to get rid of the PIR's on the wall and replace them with 360 degree PIR in the ceiling (pictured attached).
My dilemma is the PIR I currently have  6 core cables wired up and these new ones I want to order from flea bay only have 5 cables which are pre wired from the picture, can someone tell me if they will work with the panel I have or am I wasting my money?
any help or advice would be perfect.
  • 2 months later...
are you sure this ceiling PIR shown on picture is a wired intrusion PIR detector rather than a light control PIR sensor? as a wired intrusion PIR detector it comes with 5 cables is because two of them(usually red and black) serve as power input, and the other 3 serve as alarm output specifically they represent NC, NO and COM from a relay, among them you wire NC/COM to your alarm panel at hardwired zone, this ceiling PIR on picture looks like to me a decent PIR so i wonder if it should have been designed with a solid state relay rather than a electromechanical relay, so it might come with only 4 cables, this is strange. Your current has 6 cables in my opinion two of them serve as power input, another two serve alarm output(NC/COM or NO/COM), the last two serve as tamper switch.
I recently installed an 360 degree PIR in the ceiling (pictured attached). [blah..] ebay [blah...] am I wasting my money?
:yes:
As previously these look like tat, and false alarms are not fun.
Buy something half decent and proper intruder, Texecom RF360 still being made and won't break the bank...
