QSXS Posted May 11, 2016 Share Posted May 11, 2016 I would agree with sixwheeledbeast, best to face inwards, also your plan does not show an radiators,heating ducts, stoves etc, that should also be considered. And, I would be very careful of the PIR in the hall, if you have a letter box in the door. You have not indicated the location of the panel, but if you are putting it in the utility room, it could be at risk of tampering from intrusion by the fitted window. But you would be protecting against a professional. . Quote Link to comment Share on other sites More sharing options...
malfoy Posted May 11, 2016 Author Share Posted May 11, 2016 7 hours ago, QSXS said: I would agree with sixwheeledbeast, best to face inwards, also your plan does not show an radiators,heating ducts, stoves etc, that should also be considered. And, I would be very careful of the PIR in the hall, if you have a letter box in the door. You have not indicated the location of the panel, but if you are putting it in the utility room, it could be at risk of tampering from intrusion by the fitted window. But you would be protecting against a professional. . Thanks for the advice. There are almost no radiators downstairs, just one in the hallway on the right wall (wall shared with utility room) and one in the office under the window. For the PIRs I was going to take sixwheeledbeast's advice in another thread to use Bosch Blu Line for pet detectors since they can cope better with temperature variations - hence it should cope with the hallway radiator. I'll try and put as many as I can facing inwards. The panel is in the garage at the moment and I was planning on leaving it there to save rewiring the whole thing. I've already have a note in my plans to make sure I cater for the letterbox. Quote Link to comment Share on other sites More sharing options...
QSXS Posted May 11, 2016 Share Posted May 11, 2016 You have not shown a contact on the Front Door, I don't know what other think, but I would have the contact on the front door and lose the hall PIR. IMO, it does not offer much value. Quote Link to comment Share on other sites More sharing options...
Rulland Posted May 11, 2016 Share Posted May 11, 2016 I would have both. Quote Link to comment Share on other sites More sharing options...
QSXS Posted May 11, 2016 Share Posted May 11, 2016 To play devils advocate, what does it give you.? Under normal e&e, it's in Access. If you come through the window / hole in the door, possible a few second quicker notification, before ingression into one of the other zones. Possible false alarms from the letter box if fitted. I guess it guards the RKP and would also provide an extra point if alarm conformation is required. Although, I can think of one benefit from a system I did last month, as an Entry trigger in Part Arm that simplifies the functioning when using two Areas and local RKP arming. Without the trigger, the whole system would disarm. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 11, 2016 Share Posted May 11, 2016 id agree hallway pir is mainly convinience ie reminder in the morning, but still worth it Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
QSXS Posted May 11, 2016 Share Posted May 11, 2016 I am not saying its not but what is your justification? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 11, 2016 Share Posted May 11, 2016 as i said reminder in the morning. Assuming landing and all rooms of the hallway are protected then its not really a security issue but imo should always be fitted. In my experience post isnt an issue 99.9% of the time Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted May 11, 2016 Share Posted May 11, 2016 Many hallways have windows so good to have pir , or double fronted doors with glass either side, again hallway pirs are good, not much use otherwise as above and above except good reminder But then if zones are set for access in part set then wouldn't matter as another zone would remind you What's the crack with part set and zones being switched to timed access is there any issue with compliance and all that shabang What you saying monkeys? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 11, 2016 Share Posted May 11, 2016 monkey here none assuming not 8243 then setting is the issue. Reg used to say 'opening' entry door must start entry doesnt now Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
