Cheap Dvr Leaves Your Network Vulnerable To Attack
From what I've gathered in reading, no home router is safe without an outbound firewall weather it has a dvr connected or not.
Port forwarding a dvr seems to create a flag for an easy entry route for the automated hackers?
Modern plug and play dvrs are just as vulnerable...
HIK dvrs are ok?
Hmm why tell the customer that you are creating a vulnerability in their network when the network already has a vulnerability with all these automated hacking things from abroad...unles you are port forwarding which seems old hat and not done much now. Please enlighten.
I can hopefully clarify a bit.
Your own computer can be used as a pivot as well. It probably would be used as a pivot if you are running XP, with no firewall, no antivirus, out-of-date software, and you didn't care when it started crawling to a halt and the cursor started moving of it's own accord.
That's pretty much what a DVR is - out of date OS, with no firewall, no antivirus, no updates, and you can't actually see what it is doing.
Personally, I would make sure that I wasn't responsible for security issues with the DVR. I don't know the solution though, it's something we are working on in the IT security world. It's way too complex for people to get right at the moment.
And yes, Hikvision DVRs seem above average. They respond to issues, actually issue firmware updates for most gear, and there is a clear trend showing that they are improving.
http://cybergibbons.com/
no I think its best you prioritise it. The membership here needs guidance and thinks your playing all for your own benefit?
seen as you rarely frequent here till you have new info.
You probably didnt mean to come across this way, but I though the above comment was a bit rude James, Andy gives up his time FOC here I think we should be grateful for what we get. I agree it is important but his part is to tell us there is a problem, not necessarily give us all the answers as well.
