Honeywell Gx Remote Control App Connection Issue
Hi, hope you have sorted it ok. I found that every time I down powered the Router my WAN changed as we all have Dinamic IP addresses and had to change it in the settings, now I have my router fed via a 12v PSU so hopefully it should stay the same.
I am interested in knowing how do you configure outputs to operate them via the App.
Thanks,
Juan
  • 7 years later...
Hi guys I have a galaxy flex panel, also have a max3 reader outdoors which is set to a sep zone that arms and disarms the alarm for our yard outside, i know I can get the ethernet module and download the gx control app, how is this set up? Would i need a static ip addess? Or is there any other way of doing this? We use a 4g sim router (tp link) as it has the best quality signal and speeds in our area. Any kind of help would be appriciated. Thanks
Hi Niki
You would probably need to get your installer to set this up for you
