Honeywell Gx Remote Control App Connection Issue
Hi.
I've had the GX Remote working on my Galaxy Dimension panel for several weeks now, all functions were working including group setting and output switching.
Since last week the app cannot connect to the panel.
I haven't changed any settings and my older app Selfmon VKP which uses the same port number is still working no problem so I don't think it's my panel or ether net card.
Any advice would be appreciated.
Thanks
Dimension 48 version 6.92
Ethernet card version 3.02
You got it.
Got in the attic and power cycled ethernet card, app is working again.
I had only done a restart from rkp before, I wrongly thought that would reset the card. Funny how the Selfmon app continued to work.
Thanks Galaxy Guy. ☺
PS I do like the output switching and the group setting on the Honeywell app
The  E080-4 Ethernet module firmware is now at 3.05, so probably a few fixes applied since 3.02...
Yes, I need to add some more features to the SelfMon app. I still use guard codes to switch outputs at home - means I can use the keypad as well as the phone - more convenient for opening the garage door on the way out than messing with the phone.
  • 1 month later...
I can connect to my flex 20 with the app but I still get 'Groups Not Configured' and I have not control of outputs.
In regards to the outputs the app says the panel needs a firmware upgrade.
Any ideas????
