Harvir93 Posted January 7, 2016 Share Posted January 7, 2016 Hi guys. New to this forum. I've recently extended my house and fitted a new alarm system to with it. The security shop sold me a euro 46 with a zem8 expander module. I've fitted the alarm, programmed it and got it to the point of the walk test. It's recognising everything on the main panel but none of the pirs or door contacts on the expander. I've never fitted an alarm but I'm a gas fitter and electrician so didn't think it would be to difficult. Thanks. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 7, 2016 Share Posted January 7, 2016 If I came onto a gas fitters forum and said I once plumbed in an outside tap, and work in IT, so thought installing a boiler would be a piece of p155 what would your likely reaction be? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
MrHappy Posted January 7, 2016 Share Posted January 7, 2016 If I .... I was thinking along the same lines.... Howver- assuming the detection devices are wired correctly, both Inputs & ZEM's need to be programmed on ? (IIRC) Quote Mr Veritas God Link to comment Share on other sites More sharing options...
datadiffusion Posted January 7, 2016 Share Posted January 7, 2016 (edited) Apologies if it sounded harsh and I should have added I've never touched a Castle alarm since approx 2003, when it was proper old school stuff with telephone keypad RKPs, so can't actually help... What checks have you done to make sure the expander is being recognised and has the correct voltage, wiring tests etc...? Forget the actual detectors for now - I would wire a resistor of the correct EOL value into an expander zone and take it from there. This could be no more than a programming issue as H says of course... Edited January 7, 2016 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Harvir93 Posted January 7, 2016 Author Share Posted January 7, 2016 Thanks for the replies. And I completely understand where you're coming from. in terms of wiring I've used the deol line method with 2k2 and 4k7 resistors. In terms of programming the pirs and contacts are being picked up by the keypad under the diagnostics of the system for the expander. I've addressed the expander as 1 with the dip switch and 1 on the keypad. Resistances are being shown as 2.2 closed and 6.8 open for the inputs on both the main panel and expander. In terms of voltage to the expander it's showing 13.7v. I have a green flashing light on the expander which in the manual says it means data is ok. It should be solid according to the manual. Maybe a faulty unit? Quote Link to comment Share on other sites More sharing options...
Lwillis Posted January 7, 2016 Share Posted January 7, 2016 Needs to be set as Zem0 for first zen which will then use zones 9-16 Zem1 uses zones 17-24 Hope that helps Quote Link to comment Share on other sites More sharing options...
Harvir93 Posted January 7, 2016 Author Share Posted January 7, 2016 Thanks for the reply Lwillis. I uninstalled the zem from address 1. Reinstalled to 0. Moved the dipswitch back to 0 and pressed the reset switch for more than 5 secs. However when I now go into diagnostic it gives me a blank screen for the inputs of zem0. Any idea why that might be the case? Quote Link to comment Share on other sites More sharing options...
JB_ Posted January 7, 2016 Share Posted January 7, 2016 Addressed it and added it to the panel with the "Install ZEM?" option? Quote Link to comment Share on other sites More sharing options...
Harvir93 Posted January 7, 2016 Author Share Posted January 7, 2016 Yeah. I went to install zem > zem address 0 > zem installed zem 8 (1) > location I left blank. Quote Link to comment Share on other sites More sharing options...
Lwillis Posted January 7, 2016 Share Posted January 7, 2016 Add it under address 0 Come out of eng and then back in Quote Link to comment Share on other sites More sharing options...
