norman Posted November 16, 2015 Share Posted November 16, 2015 dirty dog. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
oldguy Posted November 20, 2015 Author Share Posted November 20, 2015 (edited) Dirty dog ! Nahhhhh won't dare ! ….It's about when I leave in the morning before she does when she's still in bed…..I open the front door and the keypad I put in the bedroom chimes. The other keypad is next to the front door exit. Panel is an Accenta G4, the metal box one with no keypad 8SP419A. I want the chime on the front door keypad, but not the one in the bedroom. The keypads are the LCD Gen 4 - 8EP417 Here's another query…... I have all 8 zones wired into the tamper and the overall cabling is pretty long, when i tested the tamper (continuity) it worked on the 7 zones but including the 8th it didn't, so i checked the PIR and all was good with it. So is it that the overall cable length of the tamper loop is too long with the 8th sensor….guess there are issues with resistance over long cable runs? thanks Edited November 20, 2015 by oldguy Quote Link to comment Share on other sites More sharing options...
james.wilson Posted November 20, 2015 Share Posted November 20, 2015 re resistance i dount it. WHats the reading of the series loop? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
richardsa Posted December 16, 2015 Share Posted December 16, 2015 In case this isn't already resolved....If you're using a G3 galaxy panel you should be able to mute the bedroom keypad via 58 keypad > theres an option in there for silencing it somewhere. There's an option in 51 for part set exit or something like that. ignore my reply, didn't read the whole of your last post! i'm now aware its not a gal 3! RE resistance values: there's no exact science to how long the cable can be. different panels will have different tolerances, same for the detectors. You might find that some PIR's and contacts actually have a 0.5ohm reading when short circuited others may be 0.1 so depends entirely on the real world conditions. I'd maybe try swapping the tamper pair on the last device and use any spare cores (or double up if you can). Quote Link to comment Share on other sites More sharing options...
PSE Posted December 17, 2015 Share Posted December 17, 2015 Panel is an Accenta G4, the metal box one with no keypad 8SP419A. thanks It's not a Galaxy, Quote Link to comment Share on other sites More sharing options...
