Spyman48 Posted October 11, 2015 Share Posted October 11, 2015 Hi all Can you tell me if this panel accepts a speech dialler Thanks Quote Link to comment Share on other sites More sharing options...
whistle Posted October 11, 2015 Share Posted October 11, 2015 A speech dialer will work on any panel. Quote Link to comment Share on other sites More sharing options...
PSE Posted October 11, 2015 Share Posted October 11, 2015 Yes it does, Connect it to the PGM output and configure it as required  All panels will accept a speech dialler, connect to either the +ve or -Ve output, Make sure you choose the correct polatity on the on the dialler, usually by a jumper or within the programming Quote Link to comment Share on other sites More sharing options...
Spyman48 Posted October 11, 2015 Author Share Posted October 11, 2015 Is it just triggered from the sounder Quote Link to comment Share on other sites More sharing options...
Rulland Posted October 11, 2015 Share Posted October 11, 2015 (edited) The dialler takes an input from whatever device you choose to connect it to-one just has to have a little common sense. Edited October 11, 2015 by Rulland Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 11, 2015 Share Posted October 11, 2015 Most diallers factory set to negative trigger so connecting to your bell trigger will also work if you don't know how to programme the pgm output (unless it's the same on this panel) Quote Link to comment Share on other sites More sharing options...
