NotHeardofThat1 Posted August 28, 2015 Author Share Posted August 28, 2015 ..every time I post a thread it ends up with, well. Butt talk Quote Link to comment Share on other sites More sharing options...
QSXS Posted August 31, 2015 Share Posted August 31, 2015 I have have one of these: http://www.ebay.co.uk/itm/6PCS-LED-Waterproof-5-5mm-10M-USB-Endoscope-Borescope-Tube-Inspection-Camera-/271956286475?hash=item3f51db9c0b The 90Deg, mirror is not much good, but the camera is not half bad for 8 quid. Its helped no end with dropping cables behind plaster board, looking in stud walls,looking under floor boards and fitting Flush Door contacts. Often, a 20mm hole in the floor or wall is sufficient to do keyhole cable routing. It would be nice to be able to steer the end, but you can kind of do this by rotating the cable. But for 8 quid, you can not expect too much. (Assuming you carry a laptop to use it on.) I am never without it. BTW: I always try and hide the cables to RKP, Front Door and Speaker on Domestic Installations. But it does take time. What do others do? Quote Link to comment Share on other sites More sharing options...
charlie6 Posted September 1, 2015 Share Posted September 1, 2015 Hello QSXS, At eight quid it certainly is worth a try, there are a lot of old fashioned methods I still use for those very purposes though...still not complaining for eight quid. You are quite right, the cables should be hidden but there are also ways to make it virtually invisible if neccessary. I won't bother you with the details though. There is no magic in running cable, a diyer could do it as well, and sometimes better, than those in the trade. Take Care. Quote Link to comment Share on other sites More sharing options...
