enasecurity Posted June 19, 2015 Share Posted June 19, 2015 I recently swapped out my old alarm panel and installed a premier 88(not elite), I aquired it from a friend who was moving house. The firmware on the panel is only v3.3, so I need to get this updated. it doesn't look like 3.3 has a bell on confirm option, but v10 does. Until I get hold of a flasher, can anyone tell me if there is a way to set the bellbox sounder up as confirmed alarm? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 19, 2015 Share Posted June 19, 2015 program any of the 17 outputs on the main pcb as neg applied confirmed intruder the sounder will ring until cut out? or experiment with a custom output ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
enasecurity Posted June 19, 2015 Author Share Posted June 19, 2015 Yeah will do. Btw, where can I get the v10 prem 88 software from? Texecom have discontinued the premier range now so can't find it on their website.. Quote Link to comment Share on other sites More sharing options...
PSE Posted June 20, 2015 Share Posted June 20, 2015 Send an email request to technical, Ask them to email you the firmware file for V10.02 There was also a later V11.00 from Jan 2012 that had additional changes implemented for PD6662:2010 Quote Link to comment Share on other sites More sharing options...
ensecurity Posted June 22, 2015 Share Posted June 22, 2015 Technical have just emailed me back. They don't have the files available because it's a discontinued panel. Has anyone on here got the sofrware? Quote Link to comment Share on other sites More sharing options...
PSE Posted June 22, 2015 Share Posted June 22, 2015 I have the files, But cant upload them as you're not a Trade member Get yourself registered here as a full trade member and I will give you a download link for V9.02 Quote Link to comment Share on other sites More sharing options...
ensecurity Posted June 22, 2015 Share Posted June 22, 2015 Technical have just emailed me back. They don't have the files available because it's a discontinued panel. Has anyone on here got the firmware? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted June 22, 2015 Share Posted June 22, 2015 The response will be the same from any member on here; if you are in the trade, you already have 5 posts so can apply immediately. Plus the forum is much more lively in the 'trade' section one of which is available as a non-trade member. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 Thanks datadiffusion, will apply now Quote Link to comment Share on other sites More sharing options...
breff Posted June 22, 2015 Share Posted June 22, 2015 You will only be able to take a v3 panel to v7, v8 boards had an extra nvm chip Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 Breff, the panel has 2 NVMs fitted and is running v3.3 Quote Link to comment Share on other sites More sharing options...
PSE Posted June 22, 2015 Share Posted June 22, 2015 All Premier 88 PCB’s prior to issue 13 were fitted with two 24LC128 in the sockets labelled U9 and U10. From issue 13 onwards, they were fitted with a single 24LC256 in the socket labelled U10. If the PCB is prior to issue 13 or has two 24LC128 fitted, they must be removed and a single 24LC256 fitted to the socket labelled U10. Quote Link to comment Share on other sites More sharing options...
breff Posted June 22, 2015 Share Posted June 22, 2015 I seem to remember that there is a year date on the pcb, the year date determines what software can be put in. I know that v8 needed more memory to cope with extra functions/ more log events There you go, spot on PSE Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
PSE Posted June 22, 2015 Share Posted June 22, 2015 I've got the following firmware available, V8.02, V8.13, V8.15, V9.02, Quote Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 Thanks Breff and PSE. I will check which NVMs are fitted tonight, the date code on the PCB is 10/09/02 Quote Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 The NVMs in U9 and 10 are 128s. Shall I change to a single 256 or can I still update with the 128s? Quote Link to comment Share on other sites More sharing options...
PSE Posted June 22, 2015 Share Posted June 22, 2015 Change to a 256 or you will have a door stop Quote Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 Would the 24LC256 need programming before being fitted onto the PCB? Quote Link to comment Share on other sites More sharing options...
PSE Posted June 22, 2015 Share Posted June 22, 2015 No Quote Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 What software version would be best once I've changed the chips to a single 256? Quote Link to comment Share on other sites More sharing options...
PSE Posted June 22, 2015 Share Posted June 22, 2015 Go with version 8 Quote Link to comment Share on other sites More sharing options...
enasecurity Posted June 22, 2015 Author Share Posted June 22, 2015 Thanks PSE Quote Link to comment Share on other sites More sharing options...
