Texecom Veritas R8 Plus Wont Set
i removed 3 pirs to redecorate and after the alarms went off i put in the code. i also changed the bell box as the bell was muffled. when i went to set the system zones 2-7 lights come on and it beeps 8 times. it wont let me set. i also notice 3 of the pirs does show the red led when i walk past them. i have 8 zones 1 of which is a panic. please help urgent
We can't give that info out
But it seems when you disconnected your sensors you havnt connected them back correctly
As said "above" you have problems with zones 2-7 possibly
If you didn't mess with wiring in control panel that should be ok
But zone 1 is a door contact yes? So won't help you to wire the pirs
Each pir will have a negative and positive sometimes it's red and black sometimes it isn't , but if your saying in the panel all of them are connected to +'ve then you need to check what you did in your pits again
Why don't you load some pictures of each pir here ?
