Van Racking / Storage Shelving
  • Replies 48
  • 2 weeks later...
I used to have a van that had a raised floor just over height of cable drum. Steps slotted under aswell was a great layout I thought. Steps and cable out of the way instead of kicking around the back getting in the way when all i needed was some basic tools.
that reminds me,
Jef build a step ladder box for the back of his new vans,
Jef did you every do a piccy of the completed project
Mr? Veritas God
Looking ahead to my next van, is there anything lighter than mdf but almost as strong and easy to work with?
I'm thinking some sort of plastic / composite board, for fitting out and making shelves etc...
We've used heavy duty plastic/polyprop sheet 10mm for mounting cameras before, it would probably do what you want and can be got by the sheet, but it gets expensive quickly IIRC.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
Hmm, OK thanks for the tip. I suppose I could keep weight down this time by building 'frames' that the cases etc sit in rather than on top of, using ally angle rather than fixed shelves which just add to weight / bulk...
