Recommend New Alarm System - Wireless
imran999
not relevant is it Matt.
we all know a proper sensor is always working properly. not all this sleep bollox etc...
It is relevant. You are saying the wireless option is substandard. Texecom detectors don't need to sleep. Mine are set to always report flawing your argument.
Don't get paranoid :)
Remember all that gear we all used to use on 433 for years and we've all moved on to 868 leaving the old band with nothing there so interference should be naff all. Ham band down there also deathly quiet as is cb :(
With the OP, I would go with Risco imo as you get what you require and they have their cloud for your IP cams. Only problem is you will have to get an installer in for the IP cams.
I would look at the Lightsys but have you looked at the Videofied equipment?
