Galaxy Plug On Stu Lead - Part No. A232 - Programming
Hi All,
Firstly sorry, this I guess should be in trade but awaiting approval.
I have a Galaxy 96 with the Stu Header Lead, A232.
Can anyone advise how you go about programming the triggers for this lead or what the pins are programmed as by default? Assuming they can be programmed the same way as an output?
Did try a call to Galaxy tech today but gave up after 43mins on hold!
cheers
Richard
  • Replies 54
I stood on the manual to reach the panel, left the steps in the van ;-)
In fairness I did have a quick flick though the manual on the iPad but couldn't spot it...hence the call to Galaxy tech support! bit disappointing with the 43min hold time, had that a couple of times recently with them.
I had a suspicion it was outputs 0001-0008 but thought it best check before I drove to site.
cheers for your quick response.
Richard
Richard
perhaps all in front of you hadnt found something in the manual either?
