drewabs Posted July 8, 2014 Share Posted July 8, 2014 hi guys n gals ! got a job to do and client wants all 360 detection to be hung from the girders, struggling to find a 3meter pole with a fitting to fix steel girder and then on other end the fixing plate for a 360deg pir. anyone done this before or knows where to source such fittings thanks andy Quote Link to comment Share on other sites More sharing options...
Cubit Posted July 8, 2014 Share Posted July 8, 2014 Girder fixings are bog standard, as are the bottom ends. Have a look in most supermarkets and you'll see them. You'll need girder clamps and unistrut. You'll probably need to get plates made up for the 360s Quote Link to comment Share on other sites More sharing options...
Ronnie Posted July 8, 2014 Share Posted July 8, 2014 Used them loads in PC worlds and currys - specifically for mounting 360's and audio mics but have no idea where they came from. Probably doesn't help? Quote Link to comment Share on other sites More sharing options...
Cubit Posted July 8, 2014 Share Posted July 8, 2014 QED, Preston. Quote Link to comment Share on other sites More sharing options...
drewabs Posted July 8, 2014 Author Share Posted July 8, 2014 HI RFS ! That's where ive seen them !! thanks for your help but not knowing where they are from doesn't help lol but thanks anyway. hi cubit, thanks for your reply too. ive seen and used the unistrut etc but I have seen a neat solution but carnt see it on the net. will try QED in the morning thanks Quote Link to comment Share on other sites More sharing options...
Cubit Posted July 8, 2014 Share Posted July 8, 2014 HI RFS ! That's where ive seen them !! thanks for your help but not knowing where they are from doesn't help lol but thanks anyway. hi cubit, thanks for your reply too. ive seen and used the unistrut etc but I have seen a neat solution but carnt see it on the net. will try QED in the morning thanks The poles can come with complete kits, including girder mounts. But unistrut and girder clamps always saves the day. Quote Link to comment Share on other sites More sharing options...
goncall Posted July 8, 2014 Share Posted July 8, 2014 can you not just use 20mm conduit Quote Link to comment Share on other sites More sharing options...
norman Posted July 8, 2014 Share Posted July 8, 2014 ^^ What the Geordie said ^^ 1 Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
goncall Posted July 8, 2014 Share Posted July 8, 2014 (edited) its not something ive ever done tbh,but beam clamp with conduit bracket available from neweys etc 3m length of 20mm galv or painted if required and a 20mm outlet box no plate needed then Edited July 8, 2014 by goncall Quote Link to comment Share on other sites More sharing options...
alterEGO Posted July 8, 2014 Share Posted July 8, 2014 Sunwins used conduit in the co-ops for cameras. Quote Link to comment Share on other sites More sharing options...
