Bt Infinity With Hh3
datadiffusion
That sounds like a crossword clue...
I did read anout Nat loopback issues meaning that you couldnt uee a dyn address internally. Ffs how lame!
But the issue remains even when I tried on 3G.
Another site suggest a true static Ip outside the BT dhcp range... But not sure if the hub would allow forwarding to an arbitrary ip?? I only read that afterwards. At least the site is only 2 min away and im going back in a week anyway.
Im on infinity but use a different router, same white infinity box though.
Interestingly firmware on the hh is only a week old...
Thought they were black
Surely if BT were blocking 9000 it would be well known? Tried external port scan, bt hh itself claims firewall automatically exempts port forwards...
Ah, gay port number, mines different so cant verify this works
The BT hubs can be done.
Took me a while the first time.
Don't assign a local static IP to the DVR.
Use DHCP so the DVR appears in the connected device list.
Add it as a saved device and reserve its IP and Mac address.
Create the port rules and then assign them to she DVR which is now in the list of connected devices .
Test and done.
Test and done.
That's exactly what I did do though. This is my first with infinity AND HH - my other customers ditched the HH bit when they upgraded. Last two I did on VDSL were netgear and Fritzbox, no issues. Have done ADSL HHs before many a time... Other (BT BB) forum advice is NOT to use an address within DHCP scope, set it as actual static at the device.
Oh dear... Just thinking, nothing to do with homeplugs messing about with the presented MAC is it....
Edited by datadiffusion
