datadiffusion Posted April 24, 2014 Share Posted April 24, 2014 Had a problem today which hasnt happened before... Res customer on HH3 with BT infinity. All seems to work fine. Installed SW Dvr which was fine locally, dyndns working well from Dvr pov (I.E passwords and login correct). Dyndns site showing correct public ip. Opened up relevent ports on hh. Upnp disabled. Set ip to static. Rebooted all. Just cant seem to show ports open externally.... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
matthew.brough Posted April 24, 2014 Share Posted April 24, 2014 Look on the bright side. At least no one will be hacking the DVR Quote www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
Adi Posted April 24, 2014 Share Posted April 24, 2014 so whats your issue? Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
datadiffusion Posted April 24, 2014 Author Share Posted April 24, 2014 Issue is that the Dvr can't be accessed externally... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Rulland Posted April 24, 2014 Share Posted April 24, 2014 Longer fingers required, a well known and documented problem DD....so long as a large letterbox is fitted. Quote Link to comment Share on other sites More sharing options...
Adi Posted April 24, 2014 Share Posted April 24, 2014 im on fibre with hh3, no issues, so i doubt its with the hh3. I know thats not of much help, but reckon bt have sorted out the PF issues as the last few ive done have been ok, couple of years ago, they were a mare at times. Longer fingers required, a well known and documented problem DD....so long as a large letterbox is fitted. lol Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
datadiffusion Posted April 24, 2014 Author Share Posted April 24, 2014 That sounds like a crossword clue... I did read anout Nat loopback issues meaning that you couldnt uee a dyn address internally. Ffs how lame! But the issue remains even when I tried on 3G. Another site suggest a true static Ip outside the BT dhcp range... But not sure if the hub would allow forwarding to an arbitrary ip?? I only read that afterwards. At least the site is only 2 min away and im going back in a week anyway. im on fibre with hh3, no issues, so i doubt its with the hh3. I know thats not of much help, but reckon bt have sorted out the PF issues as the last few ive done have been ok, couple of years ago, they were a mare at times. lol Im on infinity but use a different router, same white infinity box though. Interestingly firmware on the hh is only a week old... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
matthew.brough Posted April 24, 2014 Share Posted April 24, 2014 White box! That'll be the vdsl modem then . . . Quote www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
datadiffusion Posted April 24, 2014 Author Share Posted April 24, 2014 (edited) I was trying to think of the word... Modem is not technically correct I think youll find... Edited April 24, 2014 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted April 24, 2014 Share Posted April 24, 2014 Port Scanner, if it fails it's probably still a firewall issue? Try a DMZ, to prove this. Unlikely but ports can be blocked by ISP. Quote Link to comment Share on other sites More sharing options...
