MrHappy Posted December 24, 2013 Share Posted December 24, 2013 Oh dear seems no pro installers can answer the original question I would assume it was false alarming & the clicking was the piezo not vibrating correctly ? or hold off voltage too low & the product was unstable And yes its re badged scantronic r running on scantronic p.i.rs along with the label change there is a software change which prevents the scantronic devices working on the system & some terminals missing off the board (IIRC) Its outdated tat, Mr Veritas God Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 24, 2013 Share Posted December 24, 2013 Its outdated tatExactly. The fault could be any number of things but it's not worth repairing. Link to comment Share on other sites More sharing options...
norman Posted December 24, 2013 Share Posted December 24, 2013 I disagree, if the op is happy with it then a simple, inexpensive fault would be worth repairing. Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
matthew.brough Posted December 24, 2013 Share Posted December 24, 2013 I disagree, if the op is happy with it then a simple, inexpensive fault would be worth repairing. Started Christmas drinking already? www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
norman Posted December 24, 2013 Share Posted December 24, 2013 No just think in the public arena if you have nothing constructive to say, say nothing. Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 24, 2013 Share Posted December 24, 2013 No just think in the public arena if you have nothing constructive to say, say nothing.Why was recommending an upgrade not a constructive answer? Link to comment Share on other sites More sharing options...
matthew.brough Posted December 24, 2013 Share Posted December 24, 2013 Why was recommending an upgrade not a constructive answer? +1 www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
norman Posted December 24, 2013 Share Posted December 24, 2013 Why was recommending an upgrade not a constructive answer? Poor diagnosis imo, could be a simple fix. I think you need to go back and read the comments. Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
matthew.brough Posted December 24, 2013 Share Posted December 24, 2013 Poor diagnosis imo, could be a simple fix. I think you need to go back and read the comments. The film you star in is on later. I've always liked the christmas carol . . . www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
norman Posted December 24, 2013 Share Posted December 24, 2013 Just being Roy Walker. Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 24, 2013 Share Posted December 24, 2013 Poor diagnosis imo, could be a simple fix. I think you need to go back and read the comments. If you read the OP it's apparently been tested and all working at the moment. Still doesn't mean I wouldn't recommend an upgrade. Link to comment Share on other sites More sharing options...
al-yeti Posted December 28, 2013 Share Posted December 28, 2013 just to add my 2p diy worth of advice , yes put it in skip even i wouldnt touch em, but in case of the fault suggestion above sounds right , hold of voltage to low or not there, you went out came back, bell used up the internal battery , but then again i went for a repair once where the customer panicked couldnt remember the code, so opened the panel (one of those weird MDT panels mini) disconnected battery removed the mains and back up battery and waited till the bell switched off and was left with a click click click..... wheres the skip! Link to comment Share on other sites More sharing options...
