Texecom 24 Not Big Enough
jumpdyke
From day mode press menu then 4, it will tell you what software and if elite
How timely. Looked at a potential takeover yesterday, 2 office units knocked into one some time ago, I want
to add unit 2 which is currently a Veritas, but installed nicely enough with DTs, as a node to the Premier
next door, which ironically needs some work detector wise, then add Webway.
Pressed menu 4 and got given Premier 48, V8.00
Is this not Elite I guess? It was only a driveby visit and I'll pop back at some point, but not good is it?
However, assume I can just get a 48 kit and re-use one 'old' LCD Prox RKP?
Non Elite V8. Ok as long as you dont need PD6662
Thats what I meant 2010
