Bigsi Posted November 19, 2013 Share Posted November 19, 2013 Hi All I appreciate this is a fairly simple question, but this is a first Texecom install - which terminal on a Premier Elite 24 PCB should I connect my ADE Honeywell Informa Speech Dialler to? I had tried connecting to Bell+ but although I can make a test call from the dialler itself it does not dial when the alarm is triggered? Thanks in advance for any assistance. Si Quote Link to comment Share on other sites More sharing options...
Lwillis Posted November 19, 2013 Share Posted November 19, 2013 You'll need to check the trigger type for the dialler It probably -ve trigger so connect it to a programmable output an program a intruder or the bell -ve trigger Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 19, 2013 Share Posted November 19, 2013 Digicom Output 3 if you don't fancy doing any programming. Quote Link to comment Share on other sites More sharing options...
Bigsi Posted November 19, 2013 Author Share Posted November 19, 2013 Thanks for the reply. The manual shows two different outputs; 8: Panel Output 1 OP1 is a low current (500mA ‘-ve’ applied) output (see page 31 for wiring details). The output is also fully programmable (see page 69 for programming details). And 16: Digicom Outputs Outputs 1 to 8 are low current (100mA ‘-ve’ applied) and would normally be used when connecting a stand-alone communicator to the control panel (see page 31 for details). Each output is fully programmable (see page 69 for details). A remote reset input and a line fault input are also provided. Are the Digicom ones the ones to use? Thanks Si Sorry sixwheeledbeast, just seen your response. Thanks very much. How come 3 doesn't require programming? Quote Link to comment Share on other sites More sharing options...
cybergibbons Posted November 20, 2013 Share Posted November 20, 2013 Some of the outputs are pre-set to mirror other signals in the alarm. Quote I have a blog, some of which is about alarm security and reverse engineering:http://cybergibbons.com/ Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 20, 2013 Share Posted November 20, 2013 IIRC on an ELite 24 the default programming for Pin 3 is Intruder Alarm. Quote Link to comment Share on other sites More sharing options...
Bigsi Posted November 27, 2013 Author Share Posted November 27, 2013 Thanks very much. Managed to get it working on pin 3, the dialing takes around 30 seconds from the alarm going off but guess this is normal. Quote Link to comment Share on other sites More sharing options...
securitycameras Posted January 7, 2014 Share Posted January 7, 2014 Thanks for sharing this. Quote Link to comment Share on other sites More sharing options...
arfur mo Posted January 30, 2014 Share Posted January 30, 2014 (edited) the delay is so you have a chance to switch off and avoid calling key holders if you accidentally cause an activation during exit or entry. suggest check manual to allow dialler to cancel if alarm is switched off after activations, otherwise all you key holders will get a false call. Edited January 30, 2014 by arfur mo Quote If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
Pyarwood Posted June 17, 2021 Share Posted June 17, 2021 (edited) On 19/11/2013 at 22:49, Bigsi said: Thanks for the reply. The manual shows two different outputs; 8: Panel Output 1 OP1 is a low current (500mA ‘-ve’ applied) output (see page 31 for wiring details). The output is also fully programmable (see page 69 for programming details). And 16: Digicom Outputs Outputs 1 to 8 are low current (100mA ‘-ve’ applied) and would normally be used when connecting a stand-alone communicator to the control panel (see page 31 for details). Each output is fully programmable (see page 69 for details). A remote reset input and a line fault input are also provided. Are the Digicom ones the ones to use? Thanks Si Sorry sixwheeledbeast, just seen your response. Thanks very much. How come 3 doesn't require programming? Digi outputs 1 2 3 are preconfigured for (1) fire (2) PA (3) Intruder as these are standard across most speach diallers. you can re assign the to hundreds of different options if you want to reconfigure them there are a lot of standard options with each system that texecom think is a good default option. They are also programmed active high so you will need to use option [4] on the informer to alter input levels to active high. Edited June 17, 2021 by Pyarwood added info Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 17, 2021 Share Posted June 17, 2021 7 years later I think it's been solved... Also default digi outputs depend on which Texe panel, "1=fire 2=pa 3=int" is not always true. They are fully programmable obviously, also outputs are -ve applied, all this was covered above. 1 Quote Link to comment Share on other sites More sharing options...
