Honeywell Galaxy G2-12 Speaker
Dan24
Hi,
I've got a galaxy g2-12 with a standard 16 ohm speaker but the volume control doesn't seem to make a  major difference to the output, even on 1/30! I need the speaker to hear the chime inside the house, but it's way too loud even on the lowest setting, but then in alarm I want the speaker to be as loud as possible. Is my panel faulty or is it a problem across the G2 series? The tones are really high pitched compared to any other galaxy I've heard.
Has anyone else found this problem and got any way of sorting it, like if the firmware can be upgraded etc?
Thanks
I found that the volume only really worked well if you put one wire through a 1 k resistor (which'll reduce the sound too) then the volume control works better
Trade Member
