MrHappy Posted July 15, 2013 Share Posted July 15, 2013 At work I have a wired network, I need a to connect a tablet via the magic of wifi. Any recommendation for a access points ? Mr Veritas God Link to comment Share on other sites More sharing options...
fozzies Posted July 15, 2013 Share Posted July 15, 2013 Get one that supports extended service set, so you can increase range seamlessly( if it doesnt, your device will need to renew its ip every time it changes ap) Link to comment Share on other sites More sharing options...
MrHappy Posted July 15, 2013 Author Share Posted July 15, 2013 Get one that supports extended service set, so you can increase range seamlessly( if it doesnt, your device will need to renew its ip every time it changes ap) Happy towers is about as big a double garage... I was thinking something POE, nailed to a wall, locked down to mac addresses. I've only seen cisco airnet type stuff in the wild, but suspect I need something more idoit proof ? Mr Veritas God Link to comment Share on other sites More sharing options...
james.wilson Posted July 15, 2013 Share Posted July 15, 2013 i use a netgear unit. i used to have a cisco powered linksys. it was *****. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PSE Posted July 15, 2013 Share Posted July 15, 2013 Netgear recommended here, That's all we use. Fit & Forget solution Link to comment Share on other sites More sharing options...
arfur mo Posted July 15, 2013 Share Posted July 15, 2013 i use a netgear unit. i used to have a cisco powered linksys. it was *****. +1 Netgear and D-link are easy reliable units to configure, you can use an old WiFi router, just patch it to your switch panel but make sure it is not at the same address as your gateway router, as many are fixed to 192.168.(0 or 1). 1 (or 254). If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
james.wilson Posted July 15, 2013 Share Posted July 15, 2013 arf you did give me an opening there securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
arfur mo Posted July 15, 2013 Share Posted July 15, 2013 arf you did give me an opening there despite the enormous size my brain (statistical evidence of needing xxl size crash helmet), i have only normal fingers and other appendages - no cat5e plugs or sockets to connect me to Daves switch . If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
fozzies Posted July 16, 2013 Share Posted July 16, 2013 +1 Netgear and D-link are easy reliable units to configure, you can use an old WiFi router, just patch it to your switch panel but make sure it is not at the same address as your gateway router, as many are fixed to 192.168.(0 or 1). 1 (or 254). And turn off dhcp Link to comment Share on other sites More sharing options...
MrHappy Posted July 16, 2013 Author Share Posted July 16, 2013 I've pushed the boat out on capex & got a used netgear wg302 of fleabay Mr Veritas God Link to comment Share on other sites More sharing options...
