Optima XL6 manual needed
Guest pap_1
Guest mediaco
Fair enough. But this is for an elderly lady who has moved into a house with the alarm and there's no manual. Therefore, she doesn't know what keys to use to set the alarm, zones etc. The page you indicate doesn't seem to help with that.
  • Replies 76
Guest mediaco
If she was not told the code by the previose owner, then she will need to contact the installer who will be able to assist her.
If she is unable to contact the installer then if you post her general location someone on here will be able to assist.
Thanks. She has the code. But doesn't know the keys to press etc for the zones.
Hi ,
Using the user manual posted a bit further up the thread , do a walk test , make a list of the zones 1 to 6 , then trigger each detector to see which zone is indicated on the panel ,
eg
zone 1 = front door
zone 2 = hall
etc , etc.
to full set the system , just enter the code, and leave the building.Depending on the layout , she may have to omit a zone at bedtime
eg.
C O D E , omit , zone number , set.
Regards,
  • 4 months later...
Hi I have just bought a hiuse with an optima xl6 instakked but do not know the code. How do I reset the alarm? :P
We do not provide defaulting information, you will need to contact a local installer or post your location here and maybe someone can help you.
  • 2 weeks later...
Hi all
I also am new to this forum, just wanna say hi and to ask if anyone has a user manual for Optima XL6 alarm system.
(moved into my house and no instruction manual)A common problem I guess
Regards
Dave
Guest paulsolo1
Hi
any chanece of a manual for a Optima XM 6 ?
Paul.
I`ve emailed you the manual.
Edited by jameswilson
  • 1 month later...
Guest BillyAsh
Hi
Got a new house.
It has an Optima XL6 alarm, but... I don't know the code
I'm in Salford Quays, Manchester. Any help appreciated.
my email address is
