Lwillis Posted April 12, 2013 Share Posted April 12, 2013 If I remember correctly the delta bells are a +ve trigg. Unless there's a jump link on them to change that. Link to comment Share on other sites More sharing options...
sjsturner Posted April 12, 2013 Share Posted April 12, 2013 Ive never even seen one so im not sure but if thats the case then hes applying a neg currently so the trig isnt there. He says it powers up ringing i reckon he has 12v in term 1 instead of 0v If the trig is + i take it hel have to use a relay? Not installed a prem or is there prog +12v output? Link to comment Share on other sites More sharing options...
ryan042000 Posted April 12, 2013 Author Share Posted April 12, 2013 Yeh the prems can switch from pos trig to neg ( sab/ scb mode) Ill try your sugestions and get back to you tomorrow hopefully it works Link to comment Share on other sites More sharing options...
sjsturner Posted April 12, 2013 Share Posted April 12, 2013 Dont hold your breath! I havent personally installed either but thats how i would wire it. Going off what you have shown me, good luck Link to comment Share on other sites More sharing options...
Lwillis Posted April 12, 2013 Share Posted April 12, 2013 I've got a delta in the van ill have a look if you get stuck on it . Link to comment Share on other sites More sharing options...
ryan042000 Posted April 12, 2013 Author Share Posted April 12, 2013 Dat would be great lwillis then i could note it down Link to comment Share on other sites More sharing options...
Lwillis Posted April 12, 2013 Share Posted April 12, 2013 I'll have a proper look in the morning but found this online . Fairly straight forward; fault (not used) fault (not used) tamp (0v) tamp (tamp back to panel) - Tamper return 0v (ov) - Neg hold 12+ (12v) - + hold eng (not used) rtest (not used) str (- strobe trigger) - self explanatory hoff (- Bell trigger) - bell neg bt- (Battery -) Batt bt+ (Battery +) - Batt PZ1 not sure about these as someone has taken them off - PZ will stand for Piezo PZ2 - ditto. Link to comment Share on other sites More sharing options...
sjsturner Posted April 12, 2013 Share Posted April 12, 2013 I'll have a proper look in the morning but found this online . Fairly straight forward; fault (not used) fault (not used) tamp (0v) tamp (tamp back to panel) - Tamper return 0v (ov) - Neg hold 12+ (12v) - + hold eng (not used) rtest (not used) str (- strobe trigger) - self explanatory hoff (- Bell trigger) - bell neg bt- (Battery -) Batt bt+ (Battery +) - Batt PZ1 not sure about these as someone has taken them off - PZ will stand for Piezo PZ2 - ditto. Delta 6? Link to comment Share on other sites More sharing options...
Lwillis Posted April 12, 2013 Share Posted April 12, 2013 Might be , just looked up delta. Tbh I'd not refit one and use a texecom bell Link to comment Share on other sites More sharing options...
sjsturner Posted April 12, 2013 Share Posted April 12, 2013 Same here! He showed terms top of page^ We use oddy 3e Link to comment Share on other sites More sharing options...
