Max Amps/voltage Down These Cables
J_G
What's the max voltage and amps that can be sent down the following?
6 core Alarm cable....(does it affect the max voltage and amps If doubling up and is it correct if you double up? Or is it a no no?)
0.75mm flex...
1.0mm twin and earth....
1.5mm twin and earth....
2.5mm twin and earth....
Correct Fozzies,unless your connecting your t+e directly to a 10 kv substation that's the assumed voltage.
That's why the distribution network is HV, as James I squared R losses.
Without consulting the big red book Off the top of my head,
1mm around 10 amps
1.5mm around 16 amps
2.5mm around 26 amps
All dependent on clipping method/materials etc.
That's the important bit. Cable in plaster and cable in open air have two different values.
Also the question didn't state AC or DC.
I thought Twin and Earth was rated to 600V?
Rated voltages are normally in RMS values.
As for alarm cable is it a signal cable.
Rated at 1 amp per core and 50v RMS.
It is recommended to double/triple up on cores for power to reduce voltage drop.
If you can't double up both pairs, double up the negative first when using DC.
In an alarm system I wouldn't be expecting to get near the max values due to the battery capacity and rating of the PSU.
Resistance and Voltage-drop are the problem here.
  • 1 year later...
affaik stranded alarm cable is/was rated at 1amp @ 50 volts per core, double up to handle 2 amps but don't exceed 50 volts.
Doesnt matter what voltage. But the higher the voltage the less the voltage drop.
http://en.wikipedia.org/wiki/Electrical_resistivity_and_conductivity
can i qualify - as long as the voltage don't exceed the makers recommended voltage, so don't stuff 240 ac down alarm or network cable as example.
as it happens, i tried to get the voltage and current rating for CAT5e, can't seem to find it. question came up about POE cameras, so i think 48 volts DC @ 1amp.
on an american electricians forum (bless Google) one guy stated 2.5 amps no problem
