Avotronics Posted February 19, 2012 Share Posted February 19, 2012 Hi, I purchased a texecom prestige AM360 QD by mistake, meant to get the RF360. Anyway the AM is t-eol, my veritas excel is eol only. Can I still wire the AM up to my panel? Ta Danny Link to comment Share on other sites More sharing options...
Rulland Posted February 19, 2012 Share Posted February 19, 2012 Yep-just use jumpers/resistors as reqd m8. Link to comment Share on other sites More sharing options...
reidy Posted February 19, 2012 Share Posted February 19, 2012 In short no, the AMQD/DT/360 will not work with a Veritas Excel as it doesn't support the resistance values required You can get different resistor "chips" for different panels but I doubt they will do one for Veritas considering this is a Grade 3 Detector Hey Ho, Lets Go Link to comment Share on other sites More sharing options...
breff Posted February 19, 2012 Share Posted February 19, 2012 Im with Reidy, it wont work, the eol values are completely different and dont think you'll get a chip with 10k/20k Also the eol on a veritas is global so you would have to wire everything eol The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
Rulland Posted February 19, 2012 Share Posted February 19, 2012 I stand corrected having checked the specs-oops-my bad. Link to comment Share on other sites More sharing options...
Avotronics Posted February 19, 2012 Author Share Posted February 19, 2012 So pulling the resistor chip out and wiring the resistors in as normal won't work? Link to comment Share on other sites More sharing options...
reidy Posted February 19, 2012 Share Posted February 19, 2012 You don't have relay terminals to connect the resistors to, you just have the TEOL terminals unfortunately No chip = no circuit You need the RF360 for a Veritas Hey Ho, Lets Go Link to comment Share on other sites More sharing options...
itesecurity Posted February 19, 2012 Share Posted February 19, 2012 Why do texe insist on those weird eol values on the veritas anyway. Link to comment Share on other sites More sharing options...
