Ade Optima Compact Gen4 Intruder Panel, Transformer Keeps Burning Out?
phil_ad
Well im thinking back a bit now from when they moved in.. Cannot be 100% sure but will double check and get back to you tomorrow. Multimeter is currently still at work on site. cheers for the help so far and will post my readings tomorrow.
if the transformers burning out i would suggest its overloaded.
You cant rely on the fuses to prove its not overloaded as they wont blow till current is past 1.8A and the panel cannot provide that for long.
Need to know your day mode current and battery charge current.
Try a decent panel instead?
I think this is a cracking little panel for the money. Plus we still have optima 1's we installed in the 80's going strong.
QFA
