joethefixer Posted May 18, 2009 Share Posted May 18, 2009 I have a fault on my Gent 3400 that says "Wiring Changed-Ground Break at Card2". How do I identify that Outstation which has a fault on it? Is it the Loop Card or the Outstation? The system has never been touched since installation so I wonder how this fault came up. Thanks in advance. Link to comment Share on other sites More sharing options...
1019641 Posted May 18, 2009 Share Posted May 18, 2009 I have a fault on my Gent 3400 that says "Wiring Changed-Ground Break at Card2". How do I identify that Outstation which has a fault on it? Is it the Loop Card or the Outstation? The system has never been touched since installation so I wonder how this fault came up.Thanks in advance. Ground Break is a split on the Negative Conductor, Are you the maintainer or the end User, Tampering with a fire system that you don't know, expessially a gent, is not very wise. When you say "never been touched" has it been serviced, it must have been it's about 10 years old??? Let us know who you are? All the Best Dean Dean Wholey NCC Dean.Wholey@Ntlworld.com Link to comment Share on other sites More sharing options...
joethefixer Posted May 19, 2009 Author Share Posted May 19, 2009 Thanks for the reply, I'm the end user, since I'm only new with Fire Alarm Panels specially with Gent, I still need to know what are the dos and donts. Manuals available doesnt have the troubleshooting and maintenance guidelines specially with faults. You have no choice but to call for an "expert" which will just waste time. I am a PLC user and shifted to Fire Alarm Panels. Link to comment Share on other sites More sharing options...
steven sneddon Posted May 19, 2009 Share Posted May 19, 2009 Thanks for the reply, I'm the end user, since I'm only new with Fire Alarm Panels specially with Gent, I still need to know what are the dos and donts. Manuals available doesnt have the troubleshooting and maintenance guidelines specially with faults. You have no choice but to call for an "expert" which will just waste time. I am a PLC user and shifted to Fire Alarm Panels. If you haven't done any Gent training or had any experience with this type of panel before. I don't recommend touching as this could just lead to more self created problems, this is not a dig at you personally. Link to comment Share on other sites More sharing options...
soulstyle Posted May 20, 2009 Share Posted May 20, 2009 I know fire engineers that still struggle to get their heads round Gent kit. Seriously not worth messing unless you know what your doing. Its possible the best kit out there, keep it that way and call a Gent expert! Link to comment Share on other sites More sharing options...
fattypotter Posted May 20, 2009 Share Posted May 20, 2009 your outstation is gents speak for a detector, you should have a list of devices with text if not you can check in the menu, the problem you may have is to change the fault part you need to stop the loop or major problems can occur get in touch i and i will tell you of a local company that can help you find parts and give advice eddy:beer: Link to comment Share on other sites More sharing options...
luggsey Posted May 20, 2009 Share Posted May 20, 2009 I have a fault on my Gent 3400 that says "Wiring Changed-Ground Break at Card2". How do I identify that Outstation which has a fault on it? Is it the Loop Card or the Outstation? The system has never been touched since installation so I wonder how this fault came up.Thanks in advance. Gent kit can be sensitive to bumps and knocks causing this kind of fault, but, if the system is old and un-maintained chances are a detector will go faulty when the system is allocated. The ground break has not caused the system to lose any devices but if you fiddle with it chances are the loop will 'crash' and you won't be able to re-allocate it. Best left to a Gent trained engineer, honest! I would pop in and have a look but I wouldn't be home in time for tea.... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
joethefixer Posted May 21, 2009 Author Share Posted May 21, 2009 Thanks for the some details, now I can figure out how the fault came, maybe its right that allocating or resetting the card would cause this fault. Resetting the POWER may solve the problem since its still in the processor memory, Is it? Link to comment Share on other sites More sharing options...
galaxyclass Posted May 21, 2009 Share Posted May 21, 2009 got to agree with others here, messing with these panels can cause more problems than what you have now. i would advise an engineer visit prefferably from your service company. Link to comment Share on other sites More sharing options...
soulstyle Posted May 22, 2009 Share Posted May 22, 2009 Thanks for the some details, now I can figure out how the fault came, maybe its right that allocating or resetting the card would cause this fault. Resetting the POWER may solve the problem since its still in the processor memory, Is it? Give it a try. Be aware though when you power it back up all the loops will start re-allocating and if they dont allocate your in a whole world of mess if you dont play Gent. You may lose your labels also! Your a brave man, good luck tell us how it goes Link to comment Share on other sites More sharing options...
