Guest old-hand Posted May 18, 2009 Share Posted May 18, 2009 1ST lesson is keep your hands to yourself. Do not touch others items. Had one try and juggle a pair of jade eggs. They were worth 6k each!!!!!!!!!!!!!!!!!!!!!! Got him to put them down and then verbally assaulted the fool out of the house. Link to comment Share on other sites More sharing options...
hpotter Posted May 18, 2009 Share Posted May 18, 2009 True. Another possible (in the top ten) lesson is - stop wandering about pointing with that drill with 400mm bit. And if there are any philosophers why is it the more daft they (apprentices) are, the more the customer (usu female!) trys to mother them. Link to comment Share on other sites More sharing options...
y-i-out-of-bed Posted May 18, 2009 Share Posted May 18, 2009 hum calibrate the apprentice with viper tool though a soft screw driver handle dose it quite well, i mean the viper lol if thay are newer vipers a quick link will stop them flashing, but could be that set/viper reset/lights(name depends on panel and wiring) output's was not put back in properly also think solid light is FTA on first unit to triger off top of head? all my viper only flash after triger and stop on next set of system wired with lights2 on castle to set on viper needs pull up resistor as well Link to comment Share on other sites More sharing options...
