BAUERJAN Posted April 15, 2009 Share Posted April 15, 2009 Hello everybody, I have a NEXUS 8 alarm system. The standby battery is worn out and I want to replace it. If I enter the 'Engineer Code' on the remote control panel, will this disable the tamper functions? I presume that I will then be able to remove the alarm panel cover without activating the system? Is this correct? I also want to check the remote Bell Box. If I have entered the 'Engineer Code, will I be able to remove the Bellbox cover without the bell going-off? Many thanks, Jimmy Link to comment Share on other sites More sharing options...
james.wilson Posted April 15, 2009 Share Posted April 15, 2009 if you have the engineer code and the system is fully unset then yes most panels will then ignore tampers. However the external bell should still ring as the mode of the panel is irrespective to the bell. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
BAUERJAN Posted April 15, 2009 Author Share Posted April 15, 2009 if you have the engineer code and the system is fully unset then yes most panels will then ignore tampers.However the external bell should still ring as the mode of the panel is irrespective to the bell. @ redbull Many thanks for your help. Jimmy Link to comment Share on other sites More sharing options...
chexsec Posted April 15, 2009 Share Posted April 15, 2009 If the outside sounder doesn't sound, it doesn't necessarily mean it's faulty. Some panels will allow the bell tamper to open in engineer mode. I don't know about the Nexus though. Link to comment Share on other sites More sharing options...
