andymac Posted April 3, 2009 Share Posted April 3, 2009 Hi, I have just replaced my old 816 with a shiny new 595. All is well, however when I unset the system by either code or Gtag i sometimes get the message 'ACE battery low'. I do have an ACE keypad (upstairs), but i do not use any ACE fobs. Your input as usual, would be greatly appreciated. Thanks, Andy Link to comment Share on other sites More sharing options...
alterEGO Posted April 3, 2009 Share Posted April 3, 2009 Hi, I have just replaced my old 816 with a shiny new 595. All is well, however when I unset the system by either code or Gtag i sometimes get the message 'ACE battery low'. I do have an ACE keypad (upstairs), but i do not use any ACE fobs. Your input as usual, would be greatly appreciated. Thanks, Andy lol, 816 is a better panel then the 595. Make sure the ACE jumpers in the keypad don't have ace selected. Link to comment Share on other sites More sharing options...
andymac Posted April 3, 2009 Author Share Posted April 3, 2009 alterego, will check later. I never had this problem on the 816, and i havenot touched the ACE keypad. I thought 816 was a better panel (higher number) - but it was a really really old one, i think it had the year 2000 on a chip on main board! I thought the 595 stacked up ok, built in dialler etc.. What are the main differences, other than more zones, users etc.. Ta, Andy Link to comment Share on other sites More sharing options...
alterEGO Posted April 3, 2009 Share Posted April 3, 2009 alterego,will check later. I never had this problem on the 816, and i havenot touched the ACE keypad. I thought 816 was a better panel (higher number) - but it was a really really old one, i think it had the year 2000 on a chip on main board! I thought the 595 stacked up ok, built in dialler etc.. What are the main differences, other than more zones, users etc.. Ta, Andy lots of things, more fuses ect. was there a fault with the old panel? Link to comment Share on other sites More sharing options...
andymac Posted April 3, 2009 Author Share Posted April 3, 2009 No, nothing wrong with the old panel. Just very old, and wanted a dialler - the 595 seemed to be the best option. Also the police man panic button on the rkp did not work on the old panel. May be installing at my gran's! Andy Link to comment Share on other sites More sharing options...
alterEGO Posted April 3, 2009 Share Posted April 3, 2009 No, nothing wrong with the old panel. Just very old, and wanted a dialler - the 595 seemed to be the best option. Also the police man panic button on the rkp did not work on the old panel. May be installing at my gran's! Andy should have just got a dialler and a progged the old keypad so buttons 1 & 3 are panic. Link to comment Share on other sites More sharing options...
andymac Posted April 3, 2009 Author Share Posted April 3, 2009 Always wise after the event!! Anyhow - I can also get a proper wireless receiver instead of a crappy nova thingy. It gave me something to do! Andy Link to comment Share on other sites More sharing options...
Fred555 Posted April 4, 2009 Share Posted April 4, 2009 If it is an older ACE RKP you have to turn off "ACE Low Battery" otherwise you will get this message repeatedly - it is in alarm confirm (I think) try it and report back. Link to comment Share on other sites More sharing options...
andymac Posted April 4, 2009 Author Share Posted April 4, 2009 Thanks Fred, I'm not going to be home until tomorrow, will try and report back. Thanks again, Andy Link to comment Share on other sites More sharing options...
andymac Posted April 4, 2009 Author Share Posted April 4, 2009 All sorted now. Fred was correct. Turned ACE low batt of under alarm confirm. Thanks. Andy Link to comment Share on other sites More sharing options...
alterEGO Posted April 4, 2009 Share Posted April 4, 2009 All sorted now.Fred was correct. Turned ACE low batt of under alarm confirm. Thanks. Andy Should have got a new Keypad aswell the wireless is a good enough reason fo a panel upgrade as you said. Link to comment Share on other sites More sharing options...
Fred555 Posted April 7, 2009 Share Posted April 7, 2009 Glad to hear you fixed it. The really old keypads (that you could fit with the hinged flap opening to the left, right or bottom) were actually the toughest as they had two contact discs on the back of each key - all the new ones only have one carbon contact on the back of each rubber key and in our experience do not therefore last as long - but I suppose that suits the manufacturer! Link to comment Share on other sites More sharing options...
