Stewbow Posted November 21, 2008 Share Posted November 21, 2008 Model number required It's an addressable system I think it's possibly Gents The guy who ran PSA saddly passed away Thanks for any help Link to comment Share on other sites More sharing options...
luggsey Posted November 21, 2008 Share Posted November 21, 2008 Model number required It's an addressable system I think it's possibly Gents The guy who ran PSA saddly passed away Thanks for any help May be a Gent Eurofire, a better pic of the buttons would help. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
sparky999 Posted November 21, 2008 Share Posted November 21, 2008 Model number required It's an addressable system I think it's possibly Gents The guy who ran PSA saddly passed away Thanks for any help It is a Gent 800 series panel - Pete I think the rest of the manual is in the manuals section. If not PM me and I will send you more info 4188_658_I1_1.pdf Peter Robinson Freelance M:07889038650 Link to comment Share on other sites More sharing options...
luggsey Posted November 21, 2008 Share Posted November 21, 2008 It is a Gent 800 series panel - PeteI think the rest of the manual is in the manuals section. If not PM me and I will send you more info The Gent 800 I installed was oblong shaped, I think it had some blue buttons as well. Did the make a 800 this shape?? One less nought then a 8000, which is oblong shaped! Dohh! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
Stewbow Posted November 22, 2008 Author Share Posted November 22, 2008 Thanks for the input I can't find any info on the net re a Gent System 800 panel, is it no longer available? if so what can I replace it with, without changing the other sytem componants? some clown has just ripped this one off the wall and made a nice mess of the PCB Link to comment Share on other sites More sharing options...
luggsey Posted November 22, 2008 Share Posted November 22, 2008 Thanks for the inputI can't find any info on the net re a Gent System 800 panel, is it no longer available? if so what can I replace it with, without changing the other sytem componants? some clown has just ripped this one off the wall and made a nice mess of the PCB I have never fitted an 800, what sort of devices are fitted to it, are they cone shaped or doughnut shaped. (MMMM doughnuts) ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
skippy phillips Posted November 22, 2008 Share Posted November 22, 2008 800 panel was same as a euro panel. use conventional heads on addressable bases. Not sure if its obsolete or not, however unless you are gent approved you won't be able to get the software to recomission a new panel Link to comment Share on other sites More sharing options...
luggsey Posted November 22, 2008 Share Posted November 22, 2008 800 panel was same as a euro panel.use conventional heads on addressable bases. Not sure if its obsolete or not, however unless you are gent approved you won't be able to get the software to recomission a new panel When the rep came round trying to flog the Euro we told him it wasn't going to be any good, every man and his dog was using combined detection-sounder wiring then Gent brought out the Euro with separate sounders, dohh! Skippy were the bases for this the same as the "new" ones for the 2500? ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
skippy phillips Posted November 23, 2008 Share Posted November 23, 2008 Do you mean the 2400? Detection that was used was the 178xx range otherwise known as xenex but with an addressable base. Originally there was a thought that the 800 might have been a direct replacement for the 2400 but it never worked out like that Link to comment Share on other sites More sharing options...
Stewbow Posted November 23, 2008 Author Share Posted November 23, 2008 800 panel was same as a euro panel.use conventional heads on addressable bases. Not sure if its obsolete or not, however unless you are gent approved you won't be able to get the software to recomission a new panel It does have a euoropanel sticker on the front and does have conventional heads on addressable bases. Who can I speak to regarding this system? thanks Link to comment Share on other sites More sharing options...
luggsey Posted November 23, 2008 Share Posted November 23, 2008 Do you mean the 2400?Detection that was used was the 178xx range otherwise known as xenex but with an addressable base. Originally there was a thought that the 800 might have been a direct replacement for the 2400 but it never worked out like that Memory failure again, yes I did mean 2400, we did look at it (800) to replace 2400's but it was no good, we just used a vig and put T-Breakers on the lid of the zone boxes. What I was asking was did you ever use the "new" 2400 conversion bases for newer style Zennex detectors? It crossed my mind that these may be the same as 800 bases? OP you will need to speak to a Gent SI installer in your area, Gent will tell you who that is. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
skippy phillips Posted November 23, 2008 Share Posted November 23, 2008 Yeah the 800 used addressable bases for xenex detectors, not sure if they were the same for both systems though. I only saw one 800 panel in nearly 10 years with gent so don't know a great deal about them. Link to comment Share on other sites More sharing options...
mr silcox Posted December 10, 2008 Share Posted December 10, 2008 stewbow is that panel in a school in old colwyn?? Link to comment Share on other sites More sharing options...
Stewbow Posted December 17, 2008 Author Share Posted December 17, 2008 stewbow is that panel in a school in old colwyn?? no, a hmo in Rhiw Bank Avenue Link to comment Share on other sites More sharing options...
tony oliver Posted March 9, 2009 Share Posted March 9, 2009 thats a gent 800 panel it uses addressable bases, and conventional gent heads, so easy to change. u need a sort of dongle to connect to the panels comm port, and they are obsolete now. i have the 800 software if anybody needs it. Link to comment Share on other sites More sharing options...
michael777 Posted March 20, 2009 Share Posted March 20, 2009 Please help me if you have the manual of gents xenex fire alarm system with model #BS 5839-1. Thanks Link to comment Share on other sites More sharing options...
leesutton Posted March 20, 2009 Share Posted March 20, 2009 theres a company called dee fire who are gent agents if you need one.....ask for clive Lee Sutton E-Mail: leesutton@centurianfire.co.uk Website: www.centurianfire.co.uk Phone: 0845 094 9870 CENTURIAN FIRE & SECURITY (part of centurian group limited) Link to comment Share on other sites More sharing options...
sparky999 Posted March 24, 2009 Share Posted March 24, 2009 Please help me if you have the manual of gents xenex fire alarm system with model #BS 5839-1.Thanks I have a hard copy of this Pete Just checked and I have an electronic version of the manual So if you send me your e-mail address I will forward a copy to you - Pete Peter Robinson Freelance M:07889038650 Link to comment Share on other sites More sharing options...
