a1steve Posted September 21, 2008 Share Posted September 21, 2008 Hi please can any one tell me what IP Based Signalling there is and witch one is the best, I will be using a galaxy panal Link to comment Share on other sites More sharing options...
james.wilson Posted September 21, 2008 Share Posted September 21, 2008 depends. Whats the best car? There are a few but id sepak to your arc and see which they prefer as they will help guide you through after your initial training. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
mjw Posted September 21, 2008 Share Posted September 21, 2008 depends. Whats the best car?There are a few but id sepak to your arc and see which they prefer as they will help guide you through after your initial training. Redbull is right...not only that does your A.R.C have the facility to use all forms of i.p based signalling??... Link to comment Share on other sites More sharing options...
truesecurity Posted September 21, 2008 Share Posted September 21, 2008 Hi please can any one tell me what IP Based Signalling there is and witch one is the best, I will be using a galaxy panal I would use the Emizon21 signalling, if you are using a Galaxy panel then it also acts as a connection to the Galaxy remote access software. This gives you a much faster connection speed than the normal telecom module and PSTN line method. www.truesecurity.co.uk (site is still a work in progess, thoughts/advice gratefully received) Link to comment Share on other sites More sharing options...
mjw Posted September 21, 2008 Share Posted September 21, 2008 I would use the Emizon21 signalling, if you are using a Galaxy panel then it also acts as a connection to the Galaxy remote access software. This gives you a much faster connection speed than the normal telecom module and PSTN line method. See i wouldnt use emizon as i have VERY bad experience with them Link to comment Share on other sites More sharing options...
a1steve Posted September 21, 2008 Author Share Posted September 21, 2008 See i wouldnt use emizon as i have VERY bad experience with them wot about webway? Link to comment Share on other sites More sharing options...
james.wilson Posted September 21, 2008 Share Posted September 21, 2008 as above depends on what your doing, whats the application? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
mjw Posted September 21, 2008 Share Posted September 21, 2008 wot about webway? i have used webway and it is good,i found a whole lot more reliable than emizon but that is only my humble opinion Link to comment Share on other sites More sharing options...
Joe Harris Posted September 22, 2008 Share Posted September 22, 2008 All the major IP solutions have their own benifits and drawbacks. Check which types your ARC supports and list them here for some pointers. I would not like to post back my thoughts as this is a public forum, however if you can describe the premises and usage then maybe a clear winner will be easy to point out. 'J Link to comment Share on other sites More sharing options...
chemical Posted September 22, 2008 Share Posted September 22, 2008 From an ARC point of view, I would recommend Emizon everytime for IP signalling. But as previous posts have mentioned, its each to their own. ...and just because someone has had a bad experience with Emizon, doesn't mean its not worth looking at. Technical Manager NSI/LPC Approved Alarm Receiving Centre South Manchester Link to comment Share on other sites More sharing options...
